3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remove LED from Arduino Board!
       Remove that pesky pin 13 LED from your arduino board once and for all!
And in less than five minutes! talk about a quick fix.
        "Why Remove the LED?" you ask? Simple! It draws current from pin 13. so If I try to drive an external LED, like an LED matrix or a seven-segment display, the LED being driven by pin 13 won't be as bright as it's neighbors. this is an infuriating problem.
       "Can't I just disable the LED?" No, sadly, you cannot. if you look at
the LED section of the Arduino PCB board schematic,
you can see that it is hard wired into the circuit with no on/off switch.
       So, without further adieu, We shall pry at the open-source hardware that is Arduino.
Step 1Tools and Materials
Tools and Materials
PARTS and TOOLS:
  • soldering iron
  • tweezers
  • helping hands tool (this is very helpful indeed)
  • Arduino Board of your choice
The parts are shown and tagged below:
9 comments
Sep 2, 2011. 5:23 PMJordan arduino says:
i dont argue i like the led on pin 13 it elemenates
trouble of buy ing a single led i conecte pin 13 to an digital output
and it works by the way
ITS AN ARDUINO
Sep 16, 2011. 5:16 PMMudbud says:
If you have an arduino... You SHOULD have at least one LED... :P
Feb 13, 2011. 9:01 AMeverywhere says:
you may not realize that there is also a resistor on pin 13 along with the LED and that is what limits the output
Feb 21, 2011. 6:32 PMeverywhere says:
it may also just be on the duemilanove
Feb 7, 2011. 11:04 PMTheTeslaWarrior says:
why not run it through an OR gate?
Feb 10, 2011. 6:24 PMwillrandship says:
Big chip for an led :P
Feb 7, 2011. 5:26 AMOdomus says:
Though I do not have an Arduino.... I want one... but this is a good idea i have seen the videos I agree it seems to be very dull if using an external LED.
I like it.... great one just for a small little help and info.
Grats... thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:rtty21(My Electronics Project Website)
I'm a 17 year old Electronics enthusiast. I have completed two semesters of school at Minnesota State University in Mankato. I'm pursuing a degree in Electrical Engineering. I like Arduinos, C-program...
more »
