Remove these ads by
Signing UpStep 1Materials
- Soft Cloth or Disc Cleaner/Repair
- Petroleum Jelly (Vaseline, Store Brand, etc.)
- Minor to severely scratched discs
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Peanut butter
Toothpaste
Banana
Metal polish
You are spot on Solder.....
First, layer the CD with toothpaste. Then layer it with peanut butter. WIPE IT with tissue or soft cloth,you can use kitchen towel. Repeat the same process. Then dip it in the mixture of coke and soda for about 30 minutes. don't forget to shake. Then, Amazingly all the scratches of all types will be removed. This method works perfectly. For test, I had used a manually scrached CD scrached severly by rubbing it on cement surface. The result was far better than this messy valseline job.
However it would be prudent to use mild compressed air to clean out an optical drive beforehand, sometimes it is not only the disc at fault but a combination of factors including dust buildup (or other environmental pollutants like grease near a kitchen or smoke from a tobacco smoker) on the lens.
this actually worked on my sons' Thomas the tank engine DVD! that saved me some $ and also for not doing any illegal downloading! heheh
thanks a million for this very easy (and works!) instructable!
Thank you for the article anything that helps us retrieve our data and prevent it disappearing for ever is good. Once it is repaired I would recommend making 2 copies one on a HD and the other on a new optical disk.
backup the backups!
You could try the pledge method, get some lemon pledge furniture wax (Try to find something that works well with wood grain... because it will be the clearest) and then put some tape over your buttons, and screen, to protect them from pledge (Waxy residue in those area's won't be good) and start spraying a fine coat on your phone. After it's sat for a minute, then wipe it off with a news paper, or paper towel. If you want to sit and rub really hard, you can use Kleenex tissues.
Hope that helps!
I've had a LG rumor since they came out, and it's still perfect. I have the original screen plastic still on there, and no edges are coming up either. The case keeps the edges of that plastic cover from catching on anything. I keep my phone on me 24\7 in a side pocket on my jeans. It's been used a fair bit, dropped 12 times (From head height), fell in the pool once, and still works fine! In fact, the green plastic tape or w\e that is covering the buttons... only came off 4 months ago, and they were unprotected, just recessed in the case.
One downside was my camera lens.... but that's what you get for having it where it needs to be.
