3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remove Scratches from a CD/DVD with Vaseline (Petroleum Jelly)
Step 3Remove the Scratches
Once that is done, you will need to get rid of the excess grease.  If you did it with a tissue, get a damp cloth and start scrubbing.  (Do NOT use rubbing alcohol unless you want a warped disc)  If you did it with that disc cleaner on the other hand, just hit the start button, wait for it to finish, and repeat the directions above.
5 comments
Aug 22, 2011. 6:04 PMGBoss13 says:
Thanks for the help! but another tip; use a little water when cleaning off the grease
Apr 20, 2010. 5:22 PMtimothymh says:
 Tell people NOT to rub in circles, as this can cause interference itself if the cloth rubs at all. Instead, rub perpendicular to the tracks on the disk (i.e. in -> out or vice versa).
Apr 15, 2010. 10:59 AMhogtowner says:
I used window cleaner like Windex, it does the job and no problem with warping and damaging the disc.  I have seen DVDs using alcohol in a disc cleaner make a haze on the disc.  Even after the first use.  Let's face it.  Cheap plastics are used on the discs so you'll buy more and they make money.
Apr 6, 2010. 2:08 PMcoolpizzadude says:
I personally wouldn't recommend alcohol because it can warp the disk and damage the plastic.
Apr 9, 2010. 7:20 AMIfWeChoose says:
 bleh, I use alcohol all the time
Apr 9, 2010. 7:42 AMcoolpizzadude says:
Rubbing alcohol will warp the disks guaranteed if used alot.
Apr 9, 2010. 8:15 AMIfWeChoose says:
Oh, I'm on the same page as you my friend. It can warp the disk, if used a lot. The benefits of using alcohol outweigh its risks for me. And in the many years of saying SCREW IT, I have yet to damage a disk with rubbing alcohol. To protect the innocent it is a good idea to deter others from using rubbing alcohol and is a good thing to include in the instructable as you did.
Apr 9, 2010. 8:25 AMcoolpizzadude says:
Yea the only reason I brought up the subject is that I've had friends that said that they warped there disks using alcohol. But they did put alcohol on there disks every time they used them.
Apr 9, 2010. 10:37 AMIfWeChoose says:
 :O
Apr 9, 2010. 8:16 AMIfWeChoose says:
 As you did with the initial comment that is.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:gpotvin
