3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remove The Lyrics From MOST Songs
This will teach you how to remove the vocals from almost any song.
This is great for making your own Karaoke song
Now before i start i want you to know this won't completely remove the singer, but it will do a pretty good job of it so its worth a try.
Step 1Download Audacity
Download Audacity
You need to download Audacity, a free audio editing program.
First you need to go to google.com and search Audacity.
Then click on the first result which brings you to there homepage and has a download like right there.
I use the beta version but it makes no difference for this.
128 comments
1-40 of 128next »
Mar 25, 2011. 7:48 PMgangsan1996 says:
i used this on Friday by RB
Apr 26, 2011. 2:39 AMzack247 says:
geez... please dont remind me of that song!
im not trying to me mean or rude or anything but i absolutely DESPISE that song! it makes my ears bleed!
Jan 31, 2012. 4:10 AMace_gatling says:
When recording a music, sometimes the sound table controller selects Left channel for Voice and Right channel for guitar, bass and drums (or the opposite).
What I am saying is they SOMETIMES separate Voice for a exclusive channel. However, today, it's rare to see that; check out The Who songs, especially "Eminence Front"; without the Left channel you cant hear the singer except in the Chorus...
Left, Right Channels --> Search for Stereo Audio
Jan 2, 2012. 9:11 PMLittle John J13 says:
This did absolutely nothing for me, did not work. I thought you were supposed to take pride in your work on this site.
Dec 6, 2011. 3:28 AMtpennells says:
nice, remove the whole song as well as the vocals. I thought you were gonna go for some EQ or something, would have been much more effective
May 12, 2011. 4:40 PMdeiriz says:
this technique will only render the song out of phase. it will remove alot of frequencies and the song will sound empty it is not the correct way to remove frequencies.
Nov 2, 2011. 10:55 AMiceoss says:
it didnt work for me at all
Oct 20, 2011. 4:38 PMpblanscet says:
tried Awake and alive, didnt really work
you can kind of hear the lyrics
Sep 1, 2011. 6:47 PMcasey11 says:
i downloaded it but when i click on it a bunch of coding crap comes up. how do i open it?
Aug 26, 2011. 1:38 AMkratos404 says:
I made it, It Works, try to make one to Mute the Lyrics :D
Aug 8, 2011. 6:03 AMryanavellanosa says:
it worked for me. I tried The Wild Swans' song Liquid Mercury. and it worked good, and of course the accompanying sound did somewhat changed a bit. But it's good.. thanks!!
Jun 30, 2011. 7:19 AMtheudsingh says:
i didnot get you.. i download it but its not working.. :( please help me anyone.. :( upindersinghht@gmail.com
Mar 20, 2010. 12:06 PMTerry2030 says:
Hey Dancerboi,   I seem to be having a problem with step # 4.  Invert right audio.  I click in the grey area of the right bar, go click on effect the items in the drop down box are not operating.  They are all grey.  As I go down to invert it is high lighted but nothing happens when I click on it.  None of the steps after that work either.  Any suggestions ?  I have tried several songs but the same thing happens.  This a good instructable.  I think you did a good job.  I just think I am doing something wrong.
Thanks
Jun 18, 2011. 4:33 PMnwolberg says:
you need to actually press the Stop button. the big yellow square in your transport. (top left corner)
Apr 22, 2010. 4:58 PMnbagf says:
 you are doing nothing wrong just click where it says then use your mose to highlight the song.
p.s. the lyrics didn't go away for me
Mar 21, 2010. 11:59 PMProgenic says:
Since im not familiar with audacity in any way im just guessing here but i would say that your problem might be caused by your attempt to change/edit the audio file during playback.
You should check this, because what you're describing does sound very similar to what happens in most of the common audio editors when trying to add an effect or adjust/edit the audio signal in any other way during its playback.
If the same problem occurs when processing the audiofile while it is not playing, i can only say good luck...
Mar 18, 2011. 8:12 AMRaisedByRobots says:
This is interesting. It would be cool if the instructable had a before and after play button for a song that this worked on.
Mar 24, 2010. 8:27 PMsgaudreau89 says:
 I am unable to get this to work, i've tried 3 or 4 different songs and none of them work. any explanation? they're all dragged and dropped from itunes into audacity and i'd expect they're relatively high quality encodings.
Mar 10, 2011. 6:21 PMMCzone says:
import the actual file
itunes probably converted it
:{ [does it look like a man with a mustach
Apr 4, 2010. 9:41 AMAllowance10 says:
Audacity only takes Mp3...etc. Itunes uses MPEG4.
Mar 12, 2010. 6:17 PMaram.bv says:
 this will only work if the song has a good quality, means it is recorded in a studio and not reconverted after, because most of the songs you can find from internet don't have that quality, so they don't really have lyrics in one side and music in the other, and it makes it impossible to remove them in this way, but instead Audacity has another feature called Vocal Remover, I don't really know how it works for this type of files with bad quality but it's made for that :)
Mar 10, 2011. 6:16 PMMCzone says:
i am sorry i ment bad quality not bab
Mar 10, 2011. 6:15 PMMCzone says:
the bab quality vocal remover did not work for me
I did me against the world by 2pac
i love the rattling at the begining
Mar 4, 2011. 3:46 PMmacmilli says:
I have the same problem with step 4. I have the part selected but all the effects are grey. why does this not work?
Mar 9, 2011. 4:55 PMRyanxRAGE says:
I did it to "You Know My Name" by Chris Cornell and parts of the song came out garbled. Is this to be expected or is it just the song?
Dec 18, 2010. 5:37 AMfreakyqwerty says:
Congratz on using the best brouser in the world
Dec 19, 2010. 4:17 PMTYYYYLER says:
Chrome is better
Feb 19, 2011. 8:56 AMppatches24 says:
Chome alllll the wayyyy
Feb 20, 2011. 3:12 PMTYYYYLER says:
fo sho
Dec 20, 2010. 4:32 AMfreakyqwerty says:
Nah firefox 4 is better(beta)
Jan 26, 2011. 8:47 PMData643 says:
Safari FTW.
Mar 5, 2011. 5:36 PMPunktastic says:
pizza
Dec 30, 2010. 12:50 PMM4industries says:
This actually works for reasons that I don't even know. I will be using this process from now on.
Mar 12, 2010. 1:06 PMnitrodude150 says:
It works, and the guide is easy to follow, unfortunately all the base/rhythm is gone from the track =(
1-40 of 128next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:DancerBoi
I am amazing!!!!!!!!!!!!!!!!!!!!!!!!!!
