Step 4Invert Right Audio
To do this you need to click somewhere on the gray part of this bar,
then go to the Effects menu and select invert. (be sure the song is not playing when you try to do this)
The right track should look only a little different.
Thanks
p.s. the lyrics didn't go away for me
You should check this, because what you're describing does sound very similar to what happens in most of the common audio editors when trying to add an effect or adjust/edit the audio signal in any other way during its playback.
If the same problem occurs when processing the audiofile while it is not playing, i can only say good luck...
