iImage Information
Servo motors are great fun when you want to easily interface a geared motor with a micro controller. However, sometimes, you want a nice little geared motor and don't want to be bothered with control circuitry to drive it. At times like this, it is good to know how to remove the controller from inside the servo motor and convert it to direct drive. Follows are instructions for easily removing the control circuit from a servo motor.
Step 1Open it up
iImage Information
Open up the servo by removing the 4 screws fastening it closed.
Once the screws are removed, pry apart the back panel of the motor. You may be tempted to split it in the middle, as this will seem like the natural place to open it up. However, if you split it into two parts as such, it will spill out all the gears and be a mild pain in the neck to put back together.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/102/Default.aspx
But why don't you remove the limitation tab on the last gear, to allow continuous rotation? I don't see the point of not doing this.
How do you know when to stop/reverse the motor? leaving it turned on while the gear is blocked by the tab is not recommended for a too long time. Is there some other sort of feedback loop?
How do you reverse the polarity? I hope, not by powering the motor through digital outputs...
Explaining (a bit) more of your project could help me understand the purpose.
Cheers
one possibility i can think of is that there will be a normally closed switch that would cut power when the servo rotates something over to it, but without the potentiometer you wouldn’t ever know the position, also it would be at full speed and might go straight through the switch.
this just doesn’t seem to have any applications that make sense. i would be very interested to know what the author is using it for.
In this scenario, it's simply being used as a geared motor with built-in stops. I could think of tons of uses for something like this.
Now, I see the simple bots family growing:
Wobbler, Walker, ...
Should also be OK for a Most Useless Machine.
As is, removing the servo board will only allow 270 degrees or so of movement before the servo hits the endstops and the motor stalls.
The speed will be very slightly faster than the normal end-to-end speed of the servo.
