3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remove a stripped screw or bolt.
Need to remove a stripped screw or bolt? This is one of the many ways to do it, only requires a dremel.
Step 1Tools
Tools
Tools:
Dremel
Flat blad screwdriver
Dremel cut off wheel.
52 comments
1-40 of 52next »
Aug 25, 2011. 9:05 AME_MAN says:
thanks man!
Aug 15, 2011. 10:08 AMnalk55 says:
My oil drain bolt snapped off on my dirt and I was able to get it out far enough to do this.
Aug 15, 2011. 9:37 AMlukeD says:
who... Never knew it was so simple!
Jun 27, 2011. 7:02 AMzigzagchris says:
Iv been pondering how to remove a screw I striped on my laptop for a while. Any ideas? its about an inch into the base...
Aug 14, 2011. 7:15 PMswingbug62 says:
try a left hand drill bit..very slowly and with firm pressure.basically you want it to bite but not necessarily cut.
Aug 14, 2011. 9:59 AMcousin steve says:
Ive heard putting a wide rubber band between the stripped screw head and screwdriver works great.
Jun 27, 2011. 8:36 AMvideogamemaster says:
WheneverI strip screws on my technical equipment, I take a small pen torch (Or soldering iron) and heat up the head of the screw (Don't melt the plastic around it). Once the head is reasonably hot, try jamming a junk screwdriver into it (Phillips or Flat, depending on the screw type).
The hot metal is softer, allowing you to simpley drive your screwdriver into it and (hopefullly) create a new screw hole.
Hope this works. If not, let me know, ok?
Jun 27, 2011. 9:58 AMdombeef says:
Do the heating it up and use a piece of plastic to make a mold of the screw that you could use to twist it
Jun 27, 2011. 1:51 PMvideogamemaster says:
I suppose you could do that, if you have the correct type of plastic. If the screw is small enough, you can take apart a simple, clear plastic pen (Such as a Bic brand pen) and put it ontop of the screw. Heat up the plastic and it should make a form fit around the screw. Try twisting to unscrew it.
But like I've said before, be careful not to melt the plastic on the laptops casing, because that may cause problems in the future with the circuitry inside and the case.
Jun 27, 2011. 4:20 PMzigzagchris says:
What apart of the pen are you suggesting? the casing is too large for the hole and i tried the caps tip but the bent too much. I thought about the ink cartridge but m not interested in ink in my 600 dollar gaming laptop.
i dont really feel comfortable sticking a hot screwdriver in it at this point. How hot are you recomending?
Jun 27, 2011. 5:14 PMvideogamemaster says:
Lol, sorry about my other comment. I accidentally put "how how" I meant "how hot". Heh, I got distracted.
Jun 27, 2011. 5:11 PMvideogamemaster says:
Yeah, I meant the casing of the pen. But yes, I can see why you wouldn't feel comfortable jamming pieces of pens into your expensive laptop.
How how? Well, the metal of the screwdriver would need to be red-hot. I'm guessing you don't want to do that, either.
I was thinking you could go to a craft or hard ware store, and look for a knife with a long handle. You can stick it into the hole and chip away at the metal on the screw. I suggest you wear protective gloves so you don't chip away at your hands, instead.
If that doesn't work, again, let me know. I have a few more things up my sleeve.
Jun 27, 2011. 7:18 PMsunshiine says:
Nice! I will try this for one I have stuck in the wood.
Jun 27, 2011. 4:04 PMikssk says:
Try this: if the screw is sticking out of the of the wood as pictured, take your drill and tighten the chuck around the screw head, put your drill in reverse, and unscrew the screw. Works on broken screws also.
Jun 27, 2011. 3:30 PMtfultsucf says:
I've actually done this before! Except it's a bit scarier on smaller screws in visible locations where the surrounding areas can be nicked. A smaller diameter cutting head on the Dremel might help avoid this but it sure does help when you're in need of a quick fix!
Apr 22, 2008. 7:31 AMdmrsch says:
You can also use your drill and tighten the chuck around the screw head
Jun 27, 2011. 7:54 AMjimmytvf says:
Could slip as well. Thats the best and the fastest way. When I mess up a screw, i grab a bigger screwdriver, and sometimes work and sometimes dont, where you make the head completely round
Jun 27, 2011. 12:40 AMdog digger says:
But there is still a problem with that:
The Flush mount screw
(Mwohahahaha!)
Feb 22, 2009. 12:20 PMStillSteveB says:
Not sure why I never thought of this (I'm not belittling your answer; just I'm a complete spastic with this stuff), but this really got me out of a jam. Super!
Jun 27, 2011. 6:19 AMskaterqwertyuiop says:
So simple, and so useful... Why didn't I think of this method already?
Jun 27, 2011. 3:20 AMJodex says:
Drilling a hole same size as the screw through the center of the screw will also "remove" it.
Jun 18, 2011. 4:51 PMtperkins4 says:
Thanks for this post! You helped me remove my car stereo's stuck/stripped mounting screw!
Jun 11, 2011. 3:23 AMHarrymatic says:
This works very well, but I was able to just use a hacksaw.
Nov 20, 2010. 12:35 PMunaffiliatedperson says:
ha i did this to my old pocket knife. it was acheapy one and my torx bit stripped the screw holding the blade the the handle. worked great. i used a dime to tighten it from then on.
Oct 1, 2010. 11:12 PMLeOSSJ2 says:
Hey!
Today i used it for removing an engine from an old calculetor, of those whitch had someting that printed in a paper what you've been calculating...
And this method worked exelently...
Thanks a lot!
Jun 10, 2010. 4:28 PMmlucas719 says:
if you place a rubber band over the stripped screw head you can just use a screwdriver and un screw it right out. try it, been doing that forever and it's much neater
May 30, 2010. 9:23 AMahmad2117 says:
it really made a ''Bolt'' of electricity
get it a bolt of electricity and an actual bolt
May 29, 2010. 12:31 PMYerboogieman says:
What if you break a screw or bolt and don't have a reverse thread bit to get it out?
Oct 19, 2009. 9:14 AMsharlston says:
hey nice ible 5 stars another name for a cutof wheel is a iber glass cutting disc
Oct 16, 2009. 4:48 PMrada194 says:
An easier way is to use vise grips
Sep 5, 2009. 7:19 PMpuddingbeach says:
to save yourself a lot of heartach, always try going the otherway, sometimes it works...
Sep 5, 2009. 6:41 AMTetrafish says:
Ha :-D, neat. I actually did this a few days ago to some large screws I was trying to drill into some treated wood... They got so tight they wouldn't turn anymore with the drill... That is to say - they got stripped. I then took a flat head screw-driver, but wrapped a rubber dish-washing glove around the handle to get a better grip. I will not use those particular screws again unless I pre-drill a hole into the work. Another time I did something like this was to remove some screws on a micro-wave. They had weird star shaped screws in 'em.
Feb 1, 2008. 2:15 AMdominic.tarr says:
damn.. i have some stripped screws holding on the crank case of my motorcycle. i need to get them off so that I can adjust the tappets. I already tried cutting a new slot... and now the new slot is stripped! they are in mighty tight. I need to use an impact driver to remove them normally, I'll try getting some penetrating oil (used wd-40 so far), with a wax/chewing gum cup built up around the screw so it can soak in it. my other idea is to use metal putty to rebuilt the screw. don't know if it will work but any thing will be better than drilling out the whole and cutting a new thread!
Sep 5, 2009. 12:11 AMnakigara says:
I really doubt the metal putty will work. I don't know the forces involved, but I think it's a save bet that they would far exceed the adhesive strength of the putty. I've got a motorcycle myself, and I've stripped more then a couple screws and bolts on it. Impact drivers can work wonders, and are kinda fun to use as well (how often do you get to smack something with a hammer, in a legitimate attempt to fix it?) look into getting a set of screw extractors - Ive managed to use them with success, but I often break one when trying to remove it from the screw (after the screw has been removed) - Most hardware stores should have them, they have a reverse-twist thread on them, and you drill a hole in the stripped/stuck/broken screw/bolt/fastener (supposed to work better if you can use a reverse-twist drill bit, but I haven't seen these anywhere yet). then you tap the extractor in the hole, and use a tap wrench/crescent wrench in a counter-clockwise rotation. The extractor will dig into the screw, and eventually remove it. Also, good to use penetrating oil, or sometimes heat depending on what type of thread locking compound may have been used. good luck
Sep 4, 2009. 11:49 AMrobotguy4 says:
I may have found another way to remove stripped screws, however, more research is required before posting. By the way, this also works for screws you don't have a screw driver for.
Apr 27, 2009. 8:48 PMmikedoth says:
I've been doing this since I got my dremil. Good to see someone make a tutorial for it.
Apr 15, 2009. 10:12 AMrrReagaN says:
hey thanks man good idea since easy out won't work in my situation because I don't have a drill strong enough to get my bolt out :D
Apr 22, 2008. 6:42 AMJigar says:
Thanx, luckily i have a dremel. i'll try this
May 22, 2006. 12:25 AMPrometheus says:
Actually this is an old-school approach to stripped screw heads. There are alternatives when this will not work. If the mounted part is thick enough, simply drill it out and work out the reaining stud with needlenose pliers, depending on screw gauge. The alternate is prevention. Some screws are not Philips but actually "Reed & Prince", which tends to have a grabbier head hold unlenss a standard phillips has been used on it. Philips is recognised by looking at a standard stanley-brand ophilips screwdriver. Reed & Prince has a more pointy head. The alternate for such screws in metal: Place the proper-size driver in to the head of the screw, preferably one where there is direct mechanical acces to the shank. Tap the shank like you are hammering the screw in, and then try to loosen it. By doing so you introduce a component of drop-forging and thus release some of the tension from the screw, loosening it by stretching the screw. Then you can replace the screw with a new one without damage to the surounding material. If possible, heating the screw while avoiding heat transfer to the surrounding surface can help too...Penetrating lubricant like "BlasterPB" will often work loose a stubborn fastener 20X better than Liquid Wrench (which I never bother to use anymore)...See you local auto parts store for the yellow and black can...
Feb 26, 2008. 7:44 PMarcticpenguin says:
Can you explain more about the Reed & Prince screwdriver? Just googled them and their site doesn't go into drivers or anything much actually. Now I'm used to JIS (Japanese Industrial Standard) screws and drivers. Phillips look-alikes at first glance. Hard as heck to find the drivers but some Radio Controlled stores have them because often the Asian built RC helicopter blades are attached with JIS. While the screwhead looks the same, the JIS has a raised dot identifier. There is ever so slight a difference when looking at the tip between JIS and the Phillips. But I do know from experience that the Phillips driver will bugger up a JIS head so bad you'd think game is over. Then just using a JIS on that buggered head out comes the screw. Any idea where a Reed & Prince driver is sold? Are there any identifier featured on the screwhead? Are they larger screws or smaller or all kinds of heads. Now I'd really like to know if there are other Phillip-ish drivers out there. You other tips are duly noted. I've put my "secret black book of tool tips" in a dang secret place, now I can't find it. Thanks.
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
102
Author:joe
I like to tinker with just about anything, sometimes it works out in the end. Have fun looking at the projects, try tearing something open and let me know how it goes. cheers, -Joe
