Picture of Remove car dent with a lighter !
I tried this method and work very good on my old dodge.
the video remove car dent witha hair dryer and air duster
Step 1: Heat the dent
Picture of heat the dent
take a aluminium foil to protect your paint.and warm up with a lighter about 30 to 60 seconds.
Step 2: Metal contraction
Picture of metal contraction
fast apply a throw of liquid air.Hot and cold contracted the metal.
Take your Air duster for computer, and turn it upside down. This way you make liquid air available.
Apply about 5 seconds
Step 3: Now the dent is gone
Picture of now the dent is gone
just clean and its done .This method work good on medium dent.DonT work on polymer car. sorry :)
Kedakari4 years ago
I guess this is OK for small dents and old cars.
You can really ruin your car doing this.
I had better luck using suction cups.
Toilet bowl plunger works great.
Anything that the suction cups wont fix, then take it to a shop.
for some bigger dents couldn't you push it out from the inside?
I believe that is what some dent shops do, except they have specialized tools to do it. sometimes they have to drill a hole, pop it out, and fix the hole.
THEY will pop them out after heating them so the paint wont crack.
I mentioned taking it to a shop because even if you un-smash a tin can it's still not 100% lined up. Even if you do manage to make it look perfect, a lot of the metal will be weaker in areas.
Sometimes pulling one dent can shift metal over slightly so you end up with pumper covers that look twisted
So PSPerson is also right. They drill holes and pop them out so they are not stretching metal and making a wobbly mess of think metal.
afkararmani4 years ago
Wow, great tips. I want to try that.
Foaly74 years ago
Could you pull out bigger dents with a flamethrower & a fire extinguisher??? Dun Dun DaHHHHHHHH!!!!!!!!!!
mbonneau75 years ago
Does this cause damage to the paint????
i have worked in a auto body shop for 13 years and I know if you heat up the metal enough to shape it will damage the paint
I do not recomend any one try this
Take Your Car To A Pro
Prodigity5 years ago
If you put the spraycan upside down it'll generally be (alot) colder =)
mcvd26 years ago
Does anyone know where I can buy this air duster spray in The Netherlands?
shveet mcvd25 years ago
all it is, is a computer duster..really usefull
hello, i'm french, i find air duster at my supermarket ( carrefour, auchan ... migro...) with the computer stuff close to " screen cleaning wipe", otherwise in an electronic or computer shop ( i pay 8 € for a can )
Has anyone tried this and succeeded on hail dents? My dad's Citroen GSA Special thats in = MINT = condition even after 25 years of daily use just got MASHED UP by a hail storm.
He had just painted it a month ago, did all the detailing and rebuilt the dashboard from failed instruments and it looked like a spaceship!
gripes6 years ago
i tried this and it didnt work for me. yes my cars body is made of metal, but no i didnt use a straw for a concentrated spray stream. i think this is where i went wrong. also my dent is about 2 times bigger/deeper than the one shown. would this technique work for a dent of that size?
Need more heat and a really concentrated stream of Co2 from the can. But should work on a larger dent. If it's a thinner car metal and not a big ol' truck thick metal.
egreen7676 years ago
I cant get this to work. I've tried it a bunch of times.
All of our cars have hundreds of dents in them from a hail storm.
What if the dent is on top?
ag0066 years ago
does this damage the paint ?
mcvd26 years ago
Thanks Olivier. I bought the spray from Office Centre. Unfortunately, removing the dent in my car using this method didn't work (used a hair dryer).... :(
sachou6 years ago
Cool. Great idea, never thought to use heating an hyper cooling to undent cars. I usually use cheap suction cups for larger dents, but this pretty innovative
xad6 years ago
One thing i don't get is, why does the air duster foam up? Isn't it supposed to let out air only? Also, i'm guessing any kind of aerosol should do the trick? Even deodorants for those who don't have an air duster on hand :D
nafango22 xad6 years ago
no, air dusters are actually not aerosol at all, they contain a liquid similar in behavior to CO2 (liquifies under high compression, releases gas) however can be liquified at much lower temperatures and lower pressures. similar in purpose but completely different from aerosol (which uses a chemical reaction)
aaron1029776 years ago
I'm a PDR tech and I've seen many other methods of removing dents. I have had no luck with any of them. I will give this a try for sure, and I hope it does. The other method is no where this easy.
Robb6 years ago
nice instructable, but just for the record, air dusters do not contain CO2. they contain a refrigerant that is not safe to inhale. a few kids have died thinking that they contain harmless CO2 or laughing gas (N20).
tonefour6 years ago
this trick is very cool indeed! however, it looks like it'll only work for bodies of newer cars made mostly of plastic materials. I'd like to try this on my 1987 Sentra Sports Coupe made mostly of metal, but I doubt it work. =/
Madrigorne7 years ago
I am so going to try this. I have dents from a parked too close jerk who violently opened his car door - didn't even scuff the paint, but the dent is there. I bet it will pop...
kaboomspray7 years ago
"this technique cause any damage to the pain." wait, what????
second video
cyndyca7 years ago
cool but its an old trick .my brother do this method on his bike tank.Do a great job
Ohm7 years ago
I saw someone with a dented roof do this with a torch and then threw some liquid nitrogen on it, nice violent pop from that one and he was going to repaint the roof anyway.
Nice! I've always tried to think of clever ways to pull dents, but I never thought of using the properties of the metal to do so. great work!
samantha Jr7 years ago
My father tried this tip.And both work really good.My car is a toyota . But my sister have a Saturn car (made with polymer ) and after few test i donT work on her car. Thanks alot for this very very good instructable.
you should check your model saturn to see if it's the kind with plastic fenders
i did it twice on my car .nice work.
cry_wolf7 years ago
You know how amazingly awesome this is? its perfect for my mom's Lexus. It has like for dents in the side from my moms terrible parking =/
Brennn107 years ago
I am going to have to try that!
ahh, very cool!
