loading
Remove laser etching residue from wood
Featured
Picture of Remove laser etching residue from wood
I made it at TechShop
When etching wood on a laser etcher, the process can leave a residue on the surface. Many people recommend placing masking tape on the surface prior to etching. This will certainly work, but then you are left with having to remove small pieces of tape, and the power and focus of the laser may need to be adjusted to account for the extra thickness of tape. You can also lightly sand the surface after etching, but you may loose fine detail.
So let's look at this scientifically. What is the problem exactly?
Many people mistakenly believe that soot or smoke has been deposited on the surface. This is absurd. The smoke and soot particles rise from the surface, and are vacuumed away from the work piece and vented from the equipment.
The next time you laser etch a piece of wood, take a good look and feel of the residue.
Is it shiny? I've never seen shiny soot. Have you?
Is it sticky? I've never felt sticky soot. Have you?
What runs up and down, inside a tree? Hint.... you probably had it on your last stack of pancakes.
What happens when you fry onions?
You don't think of onions as being sweet, but they do contain sugar, which caramelizes with the heat. The same goes with the wood in the laser etcher. The residual sugars in the wood are released, caramelized and are deposited on the surface of the wood.
But never fear.... good old fashioned white distilled vinegar on a clean rag with take it right off!
fred271 year ago
Very useful to know. Thank you.
thank you
dermilov1 year ago
спасибо за совет !
lime3D (author)  dermilov12 months ago
вы можете
It totally works! I've only had my laser for a couple of weeks. You probably saved me a ton of money in masking products. Thank you!
pwilkins1 year ago
Mr. Clean sponges work quite well too. :) I'll try the vinegar too.
Thanks,
dpoulson1 year ago
Brilliant tip, blue tape removal is such a pain, so will see how well it turns out with this technique.
noel0leon1 year ago
Nice! Tape removal was always such a chore. Do you think it would work on things like particle board and/or MDF? Normally these materials swell up when exposed to moisture.
lime3D (author)  noel0leon1 year ago
I don't think I would try it only anything but "real" wood, but you could give it a try on a piece of scrape.
Will do, thanks!
VitaminX1 year ago
I don't understand anything, but i Loved the design...... :)
lime3D (author)  VitaminX1 year ago
Thanks. lime3D provides product design services.
tr6canuck1 year ago
Sweet!! Why don't the teachers know this?
lime3D (author)  tr6canuck1 year ago
I can't answer that. Some teach from materials that are prepared for them, and some teach from professional and life experiences. I figured it out through observation and deductive reasoning.
If you find this useful, don't forget to vote for it!
EoinM171 year ago
Same thing can happen when using a pyrographer on wood to hand burn a design onto the surface, especially when you go over a knot. This is a handy trick, I'll use it next time. Thanks!
lime3D (author)  EoinM171 year ago
It would be interesting to see if it works. With a pyrographer, you are actually burning the wood, right? With a laser etcher, it is consuming the wood.
EoinM17 lime3D1 year ago
Yeah, I guess you would just be burning the wood, but depending on the setting/heat, the pyrographer can leave quite a deep groove in the wood.
Attmos1 year ago
Thanks for posting. There are so many projects that I think would look much better without the black residue.
jpiteegorn1 year ago
NTT1 year ago
This is very handy to know. Thank you!
