An Example of Instructions
Published
Introduction: An Example of Instructions
About: Doer. maker. thinker. at scale. I update about astrophysics, gadgets, entrepreneurship, productivity, iOS/android/mobile, feminism, programming, space travel, supercomputing, photography, travel, and assorte...
Here are some instructions consumable on a wearable
Step 1: Example Mobile Instructions
Remove the protective film on the back and edge of the door or drawer front before mounting/assembly.
Step 2: Fit the Hinges
Assemble the drawer and fit the hinges.
Step 3: Cure the Surface.
Immediately after having removed the protective film the surface is especially sensitive to scratches. You can increase the surface’s resistance to scratches by curing it.
Step 4: Soft Cloth Wash.
Wash it with a soft cloth, using a mild soap solution (max. 1%). Note! Do not use any cleaners containing alcohol or abrasives
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    4 Comments
    Still confused as i thought i was on the instructables site
    yes you are! I am using these instructions, they will be updated this is just a placeholder thanks
    OK, these are great, but do you have any instructions for alleviating confusion?
    this is just an example of instructions I am creating to be useful in a mobile environment, the actual instructions will change after the mobile application is finished.
