All you need is a knife, a thumb, some rubber gloves, olive oil, and a strong potable alcohol of your choice (tequila goes best with the flavor, in my opinion).
Many people, even the great Food Network, believe that the best way to reduce the heat of a pepper is to remove the seeds. While that is quick and effective, the theory is several decades old and outdated.
Most hot peppers on the market belong to the Capsicum genus. That burning sensation is caused by capsaicin, the lipophilic substance located in the seed pod and in "blisters" lining the pepper's inner walls.
This method first dilutes and loosens the capsaicin, then dissolves it away, leaving you with strictly the pepper's flavor.
To start, you will need:
- chili pepper of your choice
- sharp paring knife
- cutting board
- olive oil
- a strong alcoholic beverage (at least 80 proof)
- latex gloves (or synthetic, whatever)
- a shot glass
- a rocks glass or "lowball" glass
Remove these ads by
Signing UpStep 1Cutting the Beast
I slipped up at the end and took one off, and that kinda ruined my day. lol
With the knife, cut the top of the pepper to remove the stem.
Next, slice one side from top to bottom to open it up.
To remove the placenta (seed pod), cut the connective tissues between it and the inner wall.
Rather than use this to strip the peppers to make them mild (i.e. useless ;-), it sounds like a great use for kicking up some major heat in a drink using 190 proof grain for the soaking.
Hmmm, I had some spare habaneros a few months back, and no time to get other ingredients for salsa, so I just cleaned them and blended them with white vinegar, then added grain for the final blend for storage. Well, either the vinegar or the grain has separated at the top of the jar......I'm wondering how that will taste ;-)
Our next party will have some... unexpected beverages. ;)
One can imagine some surprising cocktails made from Step 6 liquors!
Which peppers actually taste better after you remove the capsaicin?
Of course, the next step would be to figure out which pepper you like best for its taste, and then infuse the desired amount of capsaicin into it! I bet you could boil off most of the alcohol to purify the capasicin, and soak some sweet peppers into that...
but yeah, with (what is it- 195 proof?) everclear, no other flavor would be left after it's boiled off.
I want a vacuum chamber / heating unit. ethanol boils off at just under 80* celsius in normal pressure. if you can get the pressure low enough, it will even boil below room tempurature. they usually dont get that powerful, but you can boil off water and such without denaturing proteins or burning the other stuff in whatever you're cooking.
make a manual vacuum pump for under $20 by converting a bicycle pump
Then again, capsaicin is a fatty compound, with a boiling temperature of 210 - 220 C, so you should just be able to boil off the alcohol without the need for a vacuum chamber.
