Remove the Soldered SMD Parts Without Damage From PCB
1,211
27
7
Posted
Introduction: Remove the Soldered SMD Parts Without Damage From PCB
Remove some SMD parts from junk PCBs and reuse them is reasonable for hobbyist.
Step 1:
I use a plate of used razor.
It is very thin and tough.
Step 2:
Heat and melt the solder then insert the razor plate between the pin of part and foot print.
Step 3:
There are no heat stress and no damage.
And It is very easy way.
http://neo-sahara.com/wp/remove_part_pcb
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
7 Comments
This was a nice tip - thank you :)
I used blades from a carpet cutter which are much thicker. This is a good idea. Never thought of them (since I use an electric razor). Though I know there are used razors in the household ;-)
Please handle with care!
I know, the soldering iron is hot xD
added to favourite. you should rename it to " removing smd soldered parts...
Hi, Hashem_Mehyar.
I have changed the title, thank you.
Great, this way you prevented having a misleading title, and insured having more visits, again great tip :)
