Removing Broken Floor Tile
 by Dremel
video Removing Broken Floor Tile
Removing Broken Floor Tile with the Dremel Multi-MaxTM and the 1/8" Grout Blade #MM500 and Sanding Paper #MM900 w/ Sanding Pad #MM11
expressflooring says: Jan 21, 2011. 1:23 AM
The way the video has been presented is really very good and descriptive. http://www.expressflooring.com/tile.php
nancywilliams says: Jan 12, 2011. 1:32 AM
The post is really very good and interesting, thanks.
http://www.flooring2day.com
hardlec says: Jun 18, 2010. 1:39 PM
hoping for a reply from the author: 1: Any hope of an oscillating tool that uses some of the bits from the regular dremel, especially the polishing stuff. 2: will this tool cut the heavy wall PVC pipe uses as water mains? I have a few fountain projects, but the heavy tube has: a: Melted a dremel b: worn out several saber-saw bits c: defied efforts to cut it with a skilsaw (8 in rotary saw) I'd also like see dremel's take on a uni-mat.
tok2 says: Jun 14, 2010. 10:58 AM
ironic how all these comments are biased on being "spam" when its just "clever marketing" I will personally never use a dremel since they don't last long with the wear and tear i put them through, but as a hobby tool it is great. Obviously they are advertising for their own (who wouldn't?) Being biased enough to rant about it being spam rather than looking past the obvious. I don't own aforementioned rotary tool of said brand but that doesn't make me rant about how bad/good it is. (No, i'm not polishing my halo) good tutorial, but references to actual names of the tools would be greatly appreciated.
explosivemaker says: Nov 11, 2008. 8:02 AM
spam
xACIDITYx in reply to explosivemakerNov 19, 2008. 8:47 AM
I completely disagree.
explosivemaker in reply to xACIDITYxNov 19, 2008. 9:35 AM
....If they hadn't specifically used a dremel tool, then it wouldn't be....
xACIDITYx in reply to explosivemakerNov 19, 2008. 10:37 AM
Hardly! If I use a Dremel tool in one of my Instructables and say something like ...pick up your dremel and... is it spamming? No.
explosivemaker in reply to xACIDITYxNov 20, 2008. 9:56 AM
....a regular person making an instructable with a dremel in it would be fine....it's just when companies create profiles just to show off their own products......
Rotten194 in reply to explosivemakerMay 31, 2009. 10:44 AM
How do you know other instructables using a Dremel aren't Dremel in disguise? It doesn't matter, its just they use a Dremel. Its a helpful tutorial, and its appreciated by people with a Dremel. Its not spam. (11% of that comment was the word "Dremel")
xACIDITYx in reply to explosivemakerNov 20, 2008. 10:32 AM
I utterly disagree.
keng says: Nov 9, 2008. 9:30 PM
hmmmmm....spam or not spam?...I'm not sure here.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
