Introduction: Removing School Bus Seats
Picture of Removing School Bus Seats
2015-09-03: I made this instructable in 2008, and it's had pretty heavy and steady traffic since then. I never did follow through with my plan to make an instructable for each part of the conversion, because largely because we made stuff up as we went along.
The cross country trip was a lot of fun, we documented as much as we could at juanway.org
Since then, my partner and I have decided to turn the bus into a tiny home, you can follow this at bus.life. If you're interested in working on a similar conversion, I have a list of online resources here.
Thanks for reading, and good luck with your conversion!
Some friends and I are converting a school bus into an RV/Roadtripmobile to take across the country next summer. This summer, we're going to be doing a lot of work getting the bus (and ourselves) ready for the trip. This is something I've wanted to do for a long time, and while there are some well documented bus conversion projects online, they never quite gave me what I wanted.
So my goal with this is to address everything I had wondered about before I got my bus, and detail it simply and clearly online (both here and at our website: juanway.org). There will be more at all major stages including installing bunks, benches, basic plumbing, and getting the bus to run on veggie oil. But we're not there yet. This one is about the first major obstacle - removing the seats.
Step 1: What You'll Need
Picture of What You'll Need
You'll need a different tool depending on where you're unbolting / unscrewing.
You'll need a ratchet (socket wrench) for the nuts inside the bus.
Where the seats were bolted to the side of the bus, we used a 1/2" socket.
Where the seats were bolted in the center (next to the aisle) we used a 7/16" socket.
There were a couple odd bolts which had probably been replaced by a mechanic after the bus was manufactured, so be ready for that.
Underneath the bus, someone should hold the nut in place with a wrench (7/16" in our case).
Many sites recommend an angle grinder, to just pop the bolts off, and as far as I have seen that works, but if you have the man power, the ratchet/wrench combo is pretty easy, and several people can work at once. Also, more people are likely to have those than an angle grinder.
Step 2: Disconnect Seats From the Walls of Bus
Picture of Disconnect Seats From the Walls of Bus
This is by far the quickest part of the whole process. Have one person go around to each seat and remove the two bolts connecting the seat to the side of the bus. They'll need a ratchet and a 1/2" socket.
While this person is busy doing this, you can get started on the next step.
Step 3: Removing the Center Bolts
Picture of Removing the Center Bolts
This is the harder and more time consuming part.
One person needs to be inside the bus, and they will be turning the bolts with a ratchet (3/8" socket for us).
Another person has to go under the bus to hold the nut with a wrench (7/16" for us). You will want a work glove for this part, and I can almost promise you'll come out with cuts on your hand if you don't have one.
Communication is extremely important at this step, so open the bus windows so you can better hear each other. If the person on top is spinning the bolt, the person underneath won't be able to get a grip so it can unscrew. And of course if the two people are working on different bolts, nothing will get done.
An easy way to stay on the same page is to start at one end of the bus, so you both know what bolts you're on. The person on top can spin a bolt a little bit to show the person underneath which bolt they'll be working on. This system worked well for us, and make the process pretty quick.
Lastly, bolts will break. This bus is 18 years old, and the bolts are pretty rusty. They will break, but it usually doesn't matter, as you can still get the seats out. Less work for you!
Step 4: Remove the Seats
Picture of Remove the Seats
Remove the seats and clean up the bus.
Caulk the empty holes so nothing crawls up into your bus and makes a home.
Then you're ready to make the floor plan and start construction.
We've got a video in the next step if you want to see it.
Step 5: Video
curtis.stanley (author)2015-07-12
How much did you sell the seats for?
I am looking to buy some and I am trying to get a ball park estimate of what to pay per seat.
how many do you want?
RonythoT (author)JessicaE102016-10-07
Do you still have the seats
Well I would like to have at least 4, but possibly more.
The Lightning Stalker (author)2013-07-18
I can see some poor school bus driver somewhere pulling out of a parking space in the morning and the seats in the back start banging around.
Schmidty16 (author)2012-08-08
man my best friend and i drempt of makeing a bus into a hose on the road when we were just like 8years old and i still dream of doing it
somjuan (author)Schmidty162012-08-09
Keep an eye out for new instructables coming from me then. It's been a while, admittedly, since I posted this one, and lots has happened to the bus. It has been completely outfitted into a road trip machine, and I'm now renovating it into a 4 season camper. I'll be starting in the coming weeks, and I'll be better about documenting things this time around.
Schmidty16 (author)somjuan2012-08-09
ok i cant wait to see what u have done
somjuan (author)Schmidty162012-08-10
To keep you busy in the meantime, the website for my roadtrip is juanway.org. There's a bit of documentation on there, but not much. I'm building separate site for the bus itself, and will be documenting changes both here and there. I'll try and make some slideshows or videos of what has already been done, but I can only do so much there since it's all been completed for some time now. The rest of the project will be posted as parts are completed. This will be a slow process, and I'm not expecting to finish completely until the spring.
Schmidty16 (author)somjuan2012-08-11
ok cool ill and it to my favorits to look at here and there
Schmidty16 (author)somjuan2012-08-10
ok cool
Phaethon (author)2011-03-11
Hey, how much would you say those bus seats weigh on average? I'm trying to do some weight calculations for a project of my own, and it'd help to know what the weight of a school bus is without them.
somjuan (author)Phaethon2011-03-13
I'm not really sure - I never specifically weighed any of them, and I wouldn't say I'm good at estimating. That said, 30lbs is probably a safe bet, certainly no more than 50. I'm actually rather curious about the weight of the bus without seats as well. I've never brought it through scales, but before I made any modifications to it, the gross weight was listed as 26,000lbs. I've since added at least as much weight as the seats I removed, so I'll be sure to make a note of it if I ever get it weighed.
BodhidharmaCharma (author)2010-08-25
Nice! I've been looking to make a converted bus, and I'd love to see what you come up with. Keep "em coming, I'll be watching.
saberwing (author)2010-03-01
how do you get under the bus?
somjuan (author)saberwing2010-03-02
It's as easy as just crawling underneath.  There's a whole lot of space down there - enough to attach some sizable water tanks or cook a meal (when there is no other shade).
CameronSS (author)2008-05-21
Will your next Instructable be "What To Do With Twentysomething Bus Seats"?
somjuan (author)CameronSS2008-05-21
fair question - I was hoping I'd be able to sell them to other college students (to use in dorm rooms or whatever). but when I had been thinking that, I thought they had 4 legs...and they don't. So understandably, no one really wants them. I'm thinking of just calling up the local bus company and seeing if they're interested.
mbear (author)somjuan2009-11-13
Couldn't you just cut off the two long legs?
Richie15 (author)somjuan2009-10-29
I know a fella who uses bus seats for a horse-and-cart, or go-cart, stuff like that. But he's not the type who'd be bothered looking for someone selling them, if you know what I mean...
...I mean he steals them from the bus. :P
Weld a left seat to a right seat, you'll have a double bench with 4 legs.
Obviously you haven't ridden a bus in a long time. Having to do so twice a day for the last 6 years of my life, I can say that there is absolutely no reason to use these for seating.
Derin (author)Wolf Seril2008-10-17
the seats on my bus are pretty comfy,the driver never closes the front door so its not hot,we even have a tv
Wolf Seril (author)Derin2008-10-20
Sounds like you ride first class :)
Derin (author)Wolf Seril2008-12-11
It is a Mercedes Intouro.Google it.
Derin (author)Wolf Seril2008-10-21
they dont use the tv and no radio
It would be too weak
Derin (author)masterochicken2008-08-18
that is where braces come in
You beat me to the comment!
CameronSS (author)somjuan2008-05-21
They seem to be in good condition...If I were running the bus company, I'd buy them for replacements.
JohnJY (author)2009-10-09
You should then install the seats backwards! That'd be freak'n sweat!
twocvbloke (author)2009-04-19
Just what they need at Davesfarm... :D
http://www.youtube.com/watch?v=aBdMPWS6vT8
jetsmiley123 (author)2009-03-06
you should of mounted a beta camera with duckt tape onto the upper coner of the bus and made a time lapse of the seat removal, that would have been awesome!!!
somjuan (author)jetsmiley1232009-03-07
good call - I think we'll do that for when we build the benches and bunks.
scafool (author)2008-12-23
Keep posting your progress. I can see from your blog you have it in the school shop and are doing the conversion to run on vegetable oil instead of diesel. (Nice whale too.)
somjuan (author)scafool2008-12-23
will do - but I'm waiting until I can post a complete instructable before I post anything else
theRIAA (author)2008-05-21
paint yellow over the the "s" in school
Ora (author)theRIAA2008-05-24
chool bus?
Derin (author)Ora2008-06-13
no also paint off the h and........
"COOL BUS"
Ora (author)Derin2008-06-13
More like "C OOL BUS"
Derin (author)Ora2008-07-01
yea
fishyfish777 (author)Derin2008-09-17
CHOO
hcold (author)2008-08-30
Sorry, probably a bit of an overreaction, it appeared to me as though you were advocating lying on your back and purring. A huge overreaction.
Wolley (author)2008-08-30
A cutting torch is the fastest way, just have a fire putter outer standing by. The bolts just fall out the bottom. Rent is pretty cheap also for the work involved (labor cost). Looks cool bus livin, cool!
hcold (author)2008-08-29
(nearly) Everyone is a tax paying citizen, and responsibility is in the eye of the beholder. Don't restrict your own freedoms, just because you may get hassled for actually using them.
mr.dr.prof.joel (author)2008-05-22
iv always wanted to do this. how about you lay some carpet down then use the emergency lights as a power source for what ever u want.
Cousin eddie (author)2008-05-22
That's cool! I always wanted to make an RV out of a small bus. Beware though.... cops typically HATE RV'ers who have an obviously cheaply converted bus & will ticket/harrass them as much as possible if they think you are living in a bus fulltime (they especially hate the "hippy types" who do this). But since yours is just a party rv you probably wont have any trouble. Btw.... How hard would it be to just add an extra set of legs to those seats? Or like another poster said.... weld two seats together (but ad some kind of support legs in the middle).
aliceownsj00 (author)2008-05-22
lol, my friends and I have always wanted to do that, how much did a bus cost?
joejoerowley (author)2008-05-21
Cool!
Kozz (author)2008-05-21
That's pretty awesome. I envy you, and wish I'd done something just a *little* bit crazy back when I was unmarried and without children. ;)
You know what might be neat is if you took two of the benches from opposite sides of the aisle and re-mounted them, facing each other, on one side, with a table in the middle. It'd be a nifty dining area, if you had plans for such a thing. In fact, I somehow think it would be really neat to find new and creative ways to re-use a few of those bench seats in your construction.
I look forward to more updates on your bus project!
About This Instructable
37,930views
55favorites
License:
More by somjuan:The Anne MarieRemoving School Bus Seats
Add instructable to:
