Introduction: Removing Security Torx (Star) Screw With a Flathead Screwdriver
Security Torx screws, the six-pointed star-shaped screw heads with the pin in the middle, are used in many digital objects to prevent tampering. Removing a security torx screw can be a hassle for those without the tool. Once, however, I broke (NOT broke into, broke) a safe in a hotel room and, not wanting them to charge me excessive amounts of money for a simple repair, decided to take it apart myself. I discovered that only a small flathead is required. Oddly, this method only works on security torx, not on non-security ones.
Step 1: Aquire Your Items
To remove a security torx screw, you will need:
1) A small flathead, depending upon the size of the torx head. It will probably be a flathead.
2) The device you are attempting to access.
Step 2: Remove the Screw
Insert your small flathead into the space within the screwdriver head as shown here, and simply turn clockwise. The screw will easily come loose. Congradulations!
