Introduction: Removing Tar From Fiberglass
About: I used to work for instructables.com, now I just make stuff. // follow me to see what I'm up to: https://www.echoechostudio.com
I have just begun the restoration process of my tiny fiberglass trailer. When I pulled the windows off of the hull, there was this tar-based weather stripping sealing the window from the elements. I knew that if I was to replace the windows at any point, I would have to replace the weather stripping too, and the new weather stripping wouldn't stick to anything besides a pristine-clean surface.
I removed what I could with a razor blade and a putty knife, but there was still a thick layer of black, sticky residue remaining. I went to the hardware store and found a product called GooGone. WEARING GLOVES, I put some the solvent on a paper towel and rubbed an ample amount on to the surface of the hull. I allowed the solvent to set for a few minutes before wiping it off with another paper towel.
(Note: I am using very heavy duty shop paper toweling)
The GooGone took off, or kind of melted, most of the tar. The small amount of tar remaining cleaned up with lacquer thinner.
In summary:
1)Scrape!
2)GooGone
3)Scrape/Wipe
4)Lacquer Thinner
5)Wipe
Now to get the latex paint off the fiberglass inside......
I will be posting many Instructables about the restoration of this trailer, next up: Demolition!
