Introduction: Removing Windows Genuine Advantage
Have you ever heard Windows Genuine Advantage? Is it always reminding you about your system is not genuine? It is always bugging you, isn't it? No worries. In this Instructables, you will learn how to remove this pesky thingy...
https://www.instructables.com/files/deriv/FQ1/RE70/FPBKYB2C/FQ1RE70FPBKYB2C.MEDIUM.jpg
Step 1: Through System Restore
If you have installed WGA by mistake, you can always use your system restore to get rid of it. Restore your system to the point where WGA was not installed
Start > Accesories > System Tools > System Restore
Step 2: Through Deleting Files Manually
To remove WGA manually, follow the steps below:
Download wgakill.bat file
Double click it and restart your system
Most probably, you have successfully deleted all the files used by WGA. Now it should not come at logon.
Step 3: Manual 2 (No .bat Files)
1. Open System32 by either A or B of the following methods:
a) Click "Start", "Run", then type-in "System32". Click "Okay".
b) Find System32 manually by clicking "Start" > "My Computer" > "(X:)" (Replacing "X" with the drive letter of the host of Windows) > "Windows" > "System32".
2. In "System32", go to "Tools" > "Folder options" > click on the tab, "View" > Uncheck "Hide extensions for known file types". Now you can begin...
Check to make sure the window that comes up has a full screen of various files. The files are in alphabetical order, which makes it easier to locate the specific file.
Find "WgaLogon.dll" and rename it "WgaLogon.dll.bak".
3. Right click on a blank space in System32 and select "New" > "Text Document".
Leave the text document empty and label it "WgaLogon.dll". Press Enter (on your keyboard).
You may get a warning from the above step that says, "If you change a file name extension, the file may become unusable. Are you sure you want to change it?". Click "Yes" on this warning.
4. Be ready to complete the next two steps very quickly! Find "WgaTray.exe" in "System32" and delete it. You will then have 5 seconds to find "WgaTray.exe" in the Task Manager (the next step).
NOTE: If you remove the files mentioned above while you are in "Safe Mode," step #8 is unnecessary.
5. Immediately open Task Manager. You can do this by pressing the Ctrl, Shift, and Esc keys simultaneously, pressing the Ctrl, Alt, and Delete keys simultaneously, or right clicking the Taskbar and selecting "Task Manager". Click on the process tab and click end process when "WgaTray.exe" is selected.
Note: If you take longer, do NOT panic! All that will happen is that "WgaTray.exe" will keep reapearing in the processes list (i.e. you won't be able to delete it as required). To remove the notifications after this, return to system32. You will find two files:"WgaLogon.dll.bak" (the one you renamed) and an Application Extension (0KB) called "WgaLogon.dll". Delete the Application Extension, rename "WgaLogon.dll.bak" to "WgaLogon.dll" and repeat the steps from the third step (at a greater speed!!).
Restart your computer once you have finished. All the notification messages should be gone.
