This Picture shows pesky wasp nest.
Remove these ads by
Signing UpStep 1: Items needed for safe removal of Wasp Nest
Equipment required:
Wet Dry Vacum cleaner. Make sure air filter is installed. Inside the vacum cleaner a cotton ball soaked in acetone can be put into canister of vacum cleaner to kill wasps once sucked into vacume clearner.
A hand pressurized sprayer with liquide pesticide. Follow and read instructions on water to pestcide mixture. The pesticide can be purchased at any local hardware store.
Visit Our Store »
Go Pro Today »
Here's a link to where I bought my can of Wasp-X from:
http://www.domyownpestcontrol.com/eco-pco-jet-14-oz-can-p-104.html
Very in expensive!
Thanks for your comment.
Regards,
Which is why it's a great idea that the instructor recommends acetone in the shop-vac.
But my preferred method is using a brush and a can of liquid carburetor cleaner.
One brush stroke just beneath the nest, and they just fall to the ground. Step on them if you want to finish them quickly, but they'll die on their own anyway.
They don't get mad or aggressive. They don't attack you. They just get really messed up on the solvent and die.
For indoor use, I use a squirt bottle and rubbing alchohol. Be sure to set it on jet (NOT mist). You don't want to breath the stuff yourself, either. A near miss with a blast of the stuff puts any flying insect down right away.
Safely shoot them from a distance ...
I hate the little boogers, kill everyone of 'em I see.
The ones here are agressive and WILL sting you.
Plus it gives me reason to shoot my rifle
A note here on wasps and the like in foundations, use the extinguisher to kill off any beasties outside the entry, and then remove the large cone on the hose and insert the hose into the entry point. Vent gas in for 30 to 45 seconds (or as long as you like, you paid for the gas anyway!) If you have a basement, take the time to open the doors and keep a fan running to make sure no leakage of gas builds up in the basement. We used this to clean out a big nest in a barn foundation and had no more problem, without fire, without poison, and without a single sting!
Just my 2 cents worth
Brian
