3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Removing and Rehousing the Hard Drive from your dead Apple Time Capsule
If you're reading this, I'm going to assume that yours died and you want to get all your info off of it. Apple does not offer data recovery, and you could go to an apple certified place, the one I called here in LA told me it would cost somewhere between $300 and $1000. That's way out of my range for things that I already own.
In this instructable I'm going to show you how to crack this badboy open, remove your HD and rehouse it so that you can save at least a hundred bucks.
I bought my time capsule in '08 and it lasted longer than the 18 months many sites report to be the average lifespan. I did register it with timecapsuledead.org/, and that's where some of my research began.
Luckily Apple was kind enough to send me a new one(even though mine was out of warranty) and all they asked was that I send them my old one. Most people get this far and then fret because while getting a new one is great, their files are still on the old one. I can tell you firsthand your files are still there and still fine, the part that seems to break most often with time capsules is something related to power source. Mine went out when the power went out in my living room, but then never turned back on.
After politely explaining my predicament to apple, they re-arranged the order so that I could keep my old one, specifically to perform this experiment. Thank Apple!
I'm including my pics, much better pictures can be found here: www.flickr.com/photos/24254876@N03/2300920529/in/set-72157604011791554/
And here are much better instructions here : www.applefritter.com/node/23907
Step 1Take the rubber footing off.
 Start at one of the corners and peel back the rubber footing. This was honestly the most difficult part of the entire process, mine came off in sections and not one clean chunk, which would've been cool for my now very expensive coaster.
After you get the foot off, remove all of the screws, be sure to get the ones hiding under the glue. If it's difficult at all to remove the metal sheet then you haven't gotten all of the screws. Once you've gotten all the screws, be careful not to snap the wire that connects the two sides.
13 comments
Feb 20, 2010. 12:46 AMBuzzinski says:
This is a simple method of saving data. I have done it hundreds of times for clients (Putting hard drives into external cases that is) and I have never had a non cooled one fail on me yet.  Seeing as i live in Tropical North Queensland Australia you would expect that they would fail beacuse of over heating but they don't.
Good instructable.
Jan 14, 2012. 1:51 AMpemay08 says:
Buzzinski, can you tell me how to access my old back-ups once i have completed this. My MACBOOK recognizes the time-capsule drive, but when i enter time machine to pull old files that I need recovered, it will only let me access the current state of the computer. Thanks a bunch.
Jan 14, 2012. 1:47 AMpemay08 says:
I did this and the drive works. However, when i enter Time Machine to pull off some old files that inadvertently were deleted from my hard drive, I can only see the current status of the computer. When I hit back-up now, a white drive entitled back-up appears and I can quickly flip through here and see all the old back-ups, but do not have time to search through them before the back-up finishes and the drive 'back-up' drive disappears. What am I doing wrong here?
Apr 6, 2011. 5:47 PMThe nerdling says:
i found one all broken and dead with no hard drive and i have fixed it but i need a power suply
Dec 22, 2010. 8:57 AMscubacenote says:
Great! This makes me feel that I can probably rescue my files from my dead Mac Mini by following a similar procedure! Does anybody knows what kind of HD does the Mac Mini has? To buy the right housing that is.
Feb 20, 2010. 6:30 PMphib3r_0ptik says:
Protip:
To help to get off the rubber backing, before beginning to peel it off, heat with a hair dryer. Continue to heat as you carefully peel the rubber back. This softens the glue, which allows it to come off much easier, usually without damage
Feb 16, 2010. 3:03 AMwolfy_9005 says:
Nice, too bad it is a mac :)
Might be cheaper for people to buy a 1TB 3.5" and a housing than a time capsule.
Feb 15, 2010. 3:28 AMHolden_vy_s says:
Rotating images is a easy as opening it in an image viewer and rotating the image then closing it (In Windows) or using the image editor provided (Artworks i think it is called)
Feb 15, 2010. 5:23 PMBlackAngel999 says:
If I were you I would get an actively cooled case for my HDD. Had one crap out on me in a case that was similar to the one in your pics.
Feb 14, 2010. 11:49 PMYerboogieman says:
So does the Apple Time Capsule work with Windows?
Feb 15, 2010. 8:22 AMfwjs28 says:
i believe it does
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:oklacalit
