3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Removing stickers/labels/price tags with out sticky residue
Quick and easy should work with any solid none porous material.
Step 1Find your stuff and get started
You will need:
Cotton balls
Rubbing alcohol
Small container
Put a few cotton balls (enough to cover the sticker) in the container pour rubbing alcohol onto cotton balls just enough to be soaked up.
14 comments
Feb 14, 2011. 12:22 PMFrozenIce says:
thx
Aug 22, 2008. 4:24 PMcollard41 says:
cant you use a heater to de-stickyise (if thats a word) the glue
Aug 23, 2008. 3:30 AMcollard41 says:
sorry i meant to say with a bit of steam, and the steam doesnt need to be that hot
Feb 7, 2011. 6:15 PMBunnyLover says:
actually steam is always hot beacause it is next to plasma which doesnt exist on earth and steam is proabably always past 100 degrees celcius
Sep 10, 2008. 6:52 PMJunkyard John says:
I use cold steam to remove sticky residue all the time!
Dec 9, 2009. 4:51 PMpyra_builder_1337 says:
you can use lighter fluid as well
Nov 8, 2008. 9:10 PMMattrox says:
Hay I did this a my plastic cup started melting the cracked because of the achohol. I'm gonna sue you!!!!!!!!!! lol
Nov 25, 2009. 4:14 AMbubble_gum_chewing_gum says:
haha. it didn't work  to me. too bad. T_T
Apr 29, 2009. 1:24 PMZippy_Pyromaniac says:
Finally! I try everything to get adhesive off and it always makes me mad! thank you!
Aug 23, 2008. 3:54 PMwsround says:
WD0 does just as good with less work
Aug 23, 2008. 1:46 PMDIY Dave says:
I use WD-40
Aug 23, 2008. 1:47 AMklee27x says:
Amateur. :) Peel sticker while scraping with a razor blade. Give a couple more swipes with the razor, and glass is sparkling clean. If there's any residue left over, a touch of acetone on a bit of paper towel will take care of it.
Aug 22, 2008. 5:28 PMikoda says:
Um. For me. When I have sticky residue or pieces of the paper still stuck. I use an eraser until it comes of. It works. You could try it out too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:i make shooting things
