3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Render 3D images of your PCBs using Eagle3D and POV-Ray
Using Eagle3D and POV-Ray, you can make realistic 3D renderings of your PCBs. Eagle3D is a script for EAGLE Layout Editor. This will generate a ray tracing file, which will be sent to POV-Ray, which in turn will eventually pop out the finalized image of your PCB.
Step 1Things you'll need
-EAGLE Layout Editor -- This is the PCB CAD/CAM program used for making your PCBs. Westfw has some great tutorials on how to make a schematic and turning that into a printed circuit board using EAGLE.
-Eagle3D -- This will generate the file used by POV-Ray
-POV-Ray -- This will render the final image of the PCB.
34 comments
Aug 16, 2011. 3:17 PMrocketman221 says:
Will this render on the graphics cards or is it stuck rendering on the CPU?
Jul 10, 2011. 8:40 PMnitrox027 says:
I copied over the eagle3d files but povray says its unable to open 3edtools.inc
what can i do to fix this?
Jul 10, 2011. 8:41 PMnitrox027 says:
i am running eagle 5.10.0 and povray version 3.62
Jul 14, 2009. 6:42 AMandres2504 says:
I have this problem: Cannot open INI file 'C:\Users\user\Documents\POV-Ray\v3.6\ini\povray.ini'. Could you help me to solve this? Thanks
Jul 19, 2009. 9:15 AMandres2504 says:
sorry i've fixed it and i have obtained good results!!! thanks for the info... :D
Apr 7, 2011. 10:41 PMsteastiw says:
how did you fix it. i have the same problem. i am using windows xp.
pls help
(kindly post your reply as a comment on this post. my email id has changed. so dont mail it)
Nov 18, 2010. 3:56 PMcoleyy says:
for some reason, my switches/relays/9v battery snaps/capacity diodes all show up as disc capacitors
please help me get it to work
Aug 8, 2010. 9:04 PMdanger89 says:
My how-to: http://pastebin.ca/1913638
Jun 5, 2009. 10:03 PMpyroten says:
Could you possibly do an i'ble on how to make a small video/animation of a flyby or circling the board? I can't work it out :( According to the docs, it's possible. : D
Thanks
Jun 5, 2009. 10:04 PMpyroten says:
oh yea, and also i can't get the background to change. I'v tried everything in the settings dialog but nup.
Jul 27, 2010. 8:22 PMcdousley says:
one thing for the animation go to the little thing where you ajust the camera angle and save pictures of it at a bunch of different angles and put them together for an animation
Jun 16, 2010. 6:01 PMCybergeek004 says:
Hi I noticed that you are missing a cap in the render that happens to me to I also miss pots and other parts how can I make it so I can add all the parts in it?
Sep 27, 2009. 3:13 AMpoddy69 says:
This is just the thing I have been looking for. I love Eagle because it is so full of usefull tools and library's, and to find out that you can now make 3D images of your work is great. Only 1 problem!!!! I can't get the thing to work. Everytime I run go to render my board in POVRAY, it stops at the '#include "tools.inc". I am using the latest version of all the programs, including Eagle (which is 5.6 I think). Any ideas guys????
Aug 29, 2009. 3:21 PMRportal says:
it worked well thank you
Aug 27, 2009. 6:24 PMlunuwaththa says:
please post a article for PCB Design using Proteus 7 Professional
Feb 24, 2009. 8:07 PMcyberian says:
Excellent contribution!
Feb 19, 2009. 11:46 AMSeifpic says:
I always get an error:
Feb 23, 2009. 4:59 AMSeifpic says:
It's OK, it works now. Anyone know where to get a free working printer with its software?
Jun 26, 2008. 7:32 AMsocietyofrobots says:
I had written up a nice Eagle3D Tutorial in 2007. Its definitely worth reading through for more details . . .
Feb 22, 2009. 11:49 PMwegunterjr says:
what is the difference in eagle 5.4?
Nov 12, 2008. 10:52 PMbrandon borick says:
is eagel safe to download
Jun 4, 2008. 4:06 AMian says:
Instead of copying the include files (step #3) I added the Eagle3D path to the last line of povray.ini.
May 3, 2008. 2:49 AMawkrin says:
Crocodile 3d(which is not free) can make pcb in the same program, but it cannot render, yet is a time saver
Apr 1, 2008. 10:13 AMftking_83702 says:
Thank you so much!
Mar 25, 2008. 6:13 PMspike shadows (secret agent man) says:
thats cool, i guess it helps to see it beor you build it right? What was the circuit for, I see a 555 chip in there...
Mar 27, 2008. 9:25 PMskawesome says:
Depending on the resister values, that'll send a 5 volt pulse to the "out" pin at a regular interval. If you hooked up an LED going from "out" to "sgnd" it would blink. Also, that's really slick, good Instructable!
Mar 27, 2008. 2:59 PMJames Moxham says:
This is great - especially for creating the image on the first page of an Instructable. It also looks clearer than a photo of a real board which would be very useful for showing someone where all the parts go. +1 rating. James Moxham aka Dr_Acula
Mar 27, 2008. 2:46 PMguyfrom7up says:
:O This is the coolest thing I have ever seen related to electronics on a computer, this is like.. I dunno.. awesome!!!! +5, eh really +1 cause that's all I can do.
Mar 25, 2008. 6:29 PMwestfw says:
I was hoping someone would write this up. Thanks!
Mar 25, 2008. 6:21 PMGorillazMiko says:
Great job! These look awesome, now I can make some instead of having to draw everything out, with all the PRESSURE PUSHING DOWN ON MY SHOULDERS, CAUSING ME TO BURN INTO A PILE OF ASHES.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:ongissim
-Forever inventor -Want to be an Electronics Design Engineer -Windows will give you a glass of wine, but Unix will give you the rest of the bottle. To get the most drunk, you need to dual boot. :) ...
more »
