3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Renegade BBS in Ubuntu Linux - Telnet|Multi-Node
Step 2Create and modify the config files.
To create a generic config file for DosBox, type the following command into DosBox.
C:\> config -writeconf n1.conf
Exit DoxBox
C:\> exit
Edit the config file
$ gedit ~/renegade/n1.conf
Find the section labeled [serial] and change its contents to read as follows..
[serial]
serial1=modem listenport:2000
serial2=dummy
serial3=disabled
serial4=disabled
Now find the section called [autoexec] and add in the following lines(it should be the last section).
[autoexec]
mount c ~/renegade
c:
cd foss
fci.exe
cd ..
renegade.exe -N1
Save the config file as n1.conf
Now go back and change the listenport on serial1 from 2000 to 2001
Also change the "-N1" argument after renegade.exe in the [autoexec] section to -N2 and save as n2.conf
Repeat accordingly until you have created 4 separate config files n1 - n4.conf, utilizing listenports 2000 - 2003 and executing renegade.exe on nodes 1 - 4 using the -N<node#> argument.
(I imagine you could essentially create as many nodes as you wish.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:pyro222
