During this guide you will learn how to paint your old laptop, put any image you like on it, and water cool it for good measure.
First of all, I want to thank Jack Ruby for his water cooled laptop, which was my inspiration to do this.
Remove these ads by
Signing UpStep 1Materials and Tools
- 2 1/4" X 3" X .2mm copper sheet
- About 5 feet of 5/16 OD X 3/16 ID clear vinyl tubing
- Lots of 5 minute epoxy
- Small pump- I used this one
- 2X nylon barbed T's, 1/4 inch
- 2X nylon barb to screw adapter, 1/4 inch
- Electric wire
- Electric tape
- USB cable
- Stock Athlon CPU heatsink
- J B Weld
- Small Motherboard Northbridge heatsink
- Thermal paste
- Spray paint for plastic, your color of choice
- Clear glossy acrylic spray
- Medium grit sand paper
- Laptop LCD hinges
- Assorted screws
- Dense 5/8 inch or so thick foam
- Masking tape
- Block of wax
- Modeling clay
- 3/4 inches of thin PVC pipe
- 6 inches of 1/4 ID 3/8 OD vinyl tubing
Tools:
- Hot glue gun
- Screw driver
- 2 clamps
- Rotary tool with cutting and brushing heads
- 6 volt battery
- Pliers
- Scissors
- Wire strippers
- Box cutter/ craft knife
- Drill
- Drill Press
- 5/16 inch drill bit
- Metal cutting oil
- Goggles
- Soldering Iron + solder
63
comments
Add Comment
| 1-40 of 63 | next » |
Matrix-technician
says:
Technochicken (author)
says:
says:
TSC
says:
says:
says:
says:
says:
Add Comment
