3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair 2000-2004 Ford Focus Air Cleaner Box for under $25
Step 7Fitting, drilling and tapping the bars.
  • last photo ←
Now is the time when you are ready for the 1/2" square Aluminum or steel bars 9 1/2" long.
Put them up under where the old nuts were, and you will see where the corner on each end needs to be rounded.
With a file or grinder round the corners so they will fit up against the bottom of the bolt flange and in tight against the sides of the box.
Once they fit, it is time to mark where the holes need to be drilled.
I used a 5/16" transfer punch and tapped it lightly with a small hammer, I could not show tapping it as I needed one hand to take the picture.
I used a drill press to drill my 13/64" holes where the transfer punch had made the marks but you could drill it with a hand drill.
Use a little light oil on your tap to make it easier.
8 comments
Jun 6, 2010. 6:04 AMBosun Rick says:
Why did you use carriage bolts? For the life of me, I can't see how you can tighten them (No machined heads, & shoulders that will eventually sink into the plastic of the box). I would have inverted the carriage bolts, and used nuts on top. Saving the time & effort of fabricating the bars; or you could use angle iron (as a stiffener) with standard nuts epoxied in place.
Jun 6, 2010. 8:36 PMBosun Rick says:
My Bad, Mr. Steiner, My eyes saw "stove bolts", and my befuddled brain screamed "CARRIAGE BOLTS"! Senility is painless, unless you get caught! I apologize.
Oct 23, 2008. 3:12 PMcboy2us says:
HeHe, I would have used a dremel on the old nuts, made some grip on them, and jb-welded them. not quite as pretty, but easier, and quicker.
Oct 23, 2008. 7:07 PMcboy2us says:
Very true, and for rusty bolts I recommend aerokroil, I use it on exhaust bolts and nuts, the stuff is kinda expensive, but well worth it, I have seen it loosen rust frozen bolts that I would have broken off by trying after 24hours of soaking in wd-40.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jlsteiner
