What Is A Dust Cap?
A dust cap is the semicircular dome found in a speaker's cone. From its name, the dustcap prevents the speaker's coil form collecting and storing dust from the outside.Here's A Video:
Remove these ads by
Signing UpStep 1Tools And Materials
Tools An Materials:
(click on item where to buy)
- Black Marker- Long Nose Pliers
- 2 Thin Needles
As some other users have mentioned, there are other ways to repair a dent on a speaker's dust cap:
• use a vacuum to suck the dent out
• use your mouth suction to suck the dent out (only on large dust caps)
• use duct tape to pull the dent out
Some users have mentioned that the two pinholes created with this method could become bigger with extended use of the speaker. This is inaccurate because the dust cap itself doesn't move when the speaker is used; those users were probably thinking of the speaker's diaphragm itself, which would create large rips if any holes were punched in it.
I would also try the vacuum method first.
like it
but try a vac......
looking at the comments
that's what was on my mind
just suck the thing out
no holes no repairs
If you need to replace the cap, replacements are available. Here is a source Google just returned: http://www.speakerworks.com/dust_caps_s/66.htm .
great job......!!!!!!!!!!!!!!!!!!!!
I thought the Instructables community would be a little more accepting, but after reading comments like,
"DONT DO THIS"
I'm really not sure anymore. Good 'ible besides.
gap from the cone to the coil.
unrelated question: where did you get the speaker?
Rub a strip of masking tape or parcel tape_gently_ onto the dome. Give a quick tug to pull the dome out (ripping the tape off at the same time).
Easy-peasy!
I never tried to fix a dented cone so I learned something new very cool.
I had a computer speaker set that started make a very distorted sound it turned out that the woofer was "sticking" before I replaced the woofer I cut off the dust cap and put a small amount of talcum powder inside the distortion went away it still works well without a dust cap but I still replaced the woofer with a much better one anyway.
uncle frogy
I first learned duct tape trick when I was a sound engineer back in the late 80s.
Duct tape does work wonders --- you just gotta be resourceful!
