3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair A Powerbook AC Adapter
The cord coming out of my Powerbook AC adapter shorted out. Eventually, it even sparked and started to smoke. After this happened, having nothing to lose, I ripped it apart and made it work again. This is the story.
Step 1The Problem
The Problem
This explains how to fix an Apple Powerbook AC adapter that has a shorting cord. If your power adapter has a different problem, there might still be useful information here for you.
22 comments
Feb 28, 2012. 8:00 PMdpedersen says:
Thanks for posting this. Even 5 years later, it is still relevant. I had a rip in the cable itself and was able to splice and solder the cable back together. Thanks!
Apr 6, 2011. 11:12 PMdarmenteros says:
the adapter i was trying to fix still dos not work, I tested it but still i haven't had any reading... what could the problem be? please help..
Nov 22, 2010. 3:57 AMwheezianna says:
A1 thanks for the advice worked a treat.
Oct 25, 2010. 6:58 PMbeardy says:
It was going to happen one day - despite me never using the 'winding wings' but instead looping around the whole transformer making sure the first loop was loose. It's a weak point but it's not just Apple PSUs that suffer from this.
I even managed to keep the strain relief grommet by peeling back the rubber covering the knot then sliding it a few inches along the cable. Yay!
Incidentally, I was happy to find string inside the cable. I'm assuming it was kevlar because my scissors didn't know what to do with it ;)
Thanks for posting.
Jul 2, 2010. 1:10 AMfree1 says:
I had exactly the same problem, the wire sparked and started to smoke near the box. I opened it with knife and hammer (It was like glued together or something!) and carefully did the procedures with the wire. But my adapter refused to work again. Could it be that the wires went wrong inside the box on the circuit board? Is it this way: at the edge of the board you should solder the ground (the "hair" that is around the grey wire), and the grey wire should go more inside on the circuit board? I did this and it did not work again (no light at the other end of the chord). Now I don´t know what to do? Should I use a multimeter to check out something? Please tell how to do it. At least the power chord is okay (it is a separate one, and I took it from my portable radio that had a similar, working one), but no power is coming to the computer and my battery is running low (now only 40% left).
May 17, 2010. 1:58 PMmocristy says:
This was wonderful!!!  I am a grad student and my ac adapter finally stopped working at 4 this morning while I was working on a project.  The short was near the plug in at the laptop, but these instructions still worked.  I don't have any electrical tape with me, but I used scotch tape to work until I get back home.  It is working fine!!!  You saved me about 65 dollars.  Thank you so much!!!
Feb 4, 2010. 7:30 AMphilippeb78 says:
You could have been more respectuous of Jonathan wills by using a white tape :)
Dec 23, 2009. 9:05 PMpetpirepete says:
I had the same problem today !
My tip:
Use a hacksaw to  open the adapter (if you have one!)
Oct 30, 2009. 7:19 PMRAGOv says:
thanx a lot for the instructable, it helped :)
My sister had the same problem with her powerbook g4 adapter. I contacted apple dealers here and they asked a stupid 150$ and 20 days to get me the adapter :O...this was stealing (they said that the powerbook is old and they do not have it's replacements), plus, 20 days was like impossible, cuz my sister has work and she uses her powerbook all the time...
Well, as google is my friend, and instructables.com is my other friend, i managed to fix it and she's up and running again :)
thank you from all my heart for this...respect ;)
Oct 2, 2009. 11:59 PMbluefly1215 says:
Mine also died. but I think it was because my cat ate the cord. This still may help me to fix it and keep a backup. I have more cords that my cat has eaten. bummer, too many of them... and I can't fix them all. thanks!
Jul 1, 2009. 7:24 PMtwocvbloke says:
I find that hitting sealed transformer casings fairly hard multiple times along the seams can open them soon enough to gain access to the guts, or if you're not bothered about salvaging the casing (either component harvesting or have a project box replacement on standby), just crush the case in a vice until it pops apart... :)
Jan 22, 2009. 12:54 AMllerena says:
Unbelievable!.. All of a sudden my girlfriend's power adapter stopped working, and I immediately went to Google for help... I searched for "fixing apple powerbook power adapter" and ended up at this link in this amazing website that is Instructables.com. Anyway, we had already chopped off the cable and tried making it work on our own, making use of our own "Macgiver" qualities. Nothing happened, so we decided to try whatever, since she really needed to make her laptop work so she could work... We followed the instructions, step by step, we sawed the adapter, she even sliced her thumb in the process, so, be careful if you try it, 'cause I never imagined these things were so definately sealed forever!.. After opening the adapet and splicing the cables, connecting it all together and wrapping the adapter with tape, she immediately plugged it in, and guess what?!. The power adapter's power light actually lit up! Yes, it worked!!! This whole site is amazing, this instruction link for the adapter is great and detailed, even though I never got to understand why it made any difference having to open the adapter, since we didn't actually get around doing anything in there... So, try connecting the cables thoroughly and the best way possible before opening the adapter, 'cause it is a real ordeal. Anyway, gotta get back to work now!.. ;)
Sep 5, 2008. 7:11 PMGlassEye1 says:
I had a short at the computer-side of the power-adapter. My local Apple store gave me a free 85 Watt power-adapter. When that didn't work they replaced my logic board, DVD/Superdrive & power harness all for free. My wife found out Apple was having a -- Uh-Hmm, err -- "issue" with these power-adapters and quietly replacing them (That's why I took to the Apple store). It's on the Apple site, but you have to dig (sorry I don't have the URL). Just a word of caution for DIYers -- Have good commercial soldering iron with a needle-point tip and a good Solder-sucker. My Solder-sucker worked great, but my $10 Radio-Shack soldering iron was inadequate.
Aug 20, 2008. 7:16 AMkriswatson says:
Came across your site by chance and what a relief i did, awesome job, what a great idea and great service to offer people who dont want to keep buying expensive cables (as much as i love Apple they do change up the ying yang) tired your advice and worked first time, this is the 3rd cable i have had Great job, thank you. Kris
May 7, 2008. 8:40 AMasimegusta says:
Thanks guy. What a relief to have repaired the power adapter on my Toshiba laptop. Your instrutions are great. I needed to splice both the wire and the sheathing though, else got no power. Thanks for sharing.
Jan 22, 2008. 8:33 PMevea says:
amazing - thank you so much. costed me $8 for soldering wire and electrical tape! vs $80 - totally dope... i heard on another site: apple will replace this adaptor (even if your computer is out of warranty) if you say it started smoking. I was gonna do this, but then i thought "REDUCE, RECYCLE, REUSE"! this solution is definitely easier on mother earth.
Jul 4, 2007. 4:30 PMpgw says:
Geat web page. We have 4 plyful kitties. I repaied the power adaptor cord to my G4 powerbook using the instructions provided. Saved ~$80. Thanks! I used an exacto knife to free the wires. One protected bundle was surrounded by the other wires (hence coaxial?). I teased the bundle out and slit the length of very tough covering to relase the wires. These are hard to see and may not be obvious to neophytes like myself. Given your webpage, I placed the entire cord lengthwise bewteen long strips of electrical tape, hoping to prevent twisting and tears, ect. Thanks again.
Mar 10, 2007. 2:15 PMRobyntheslug says:
Mine shorted out as well X_x Wonder If I can make this work? Thanks!
Mar 10, 2007. 1:18 PMjohnson_steve says:
You know mine shorted out in the exact same place. I wonder how many of these this has happened to? I fixed mine almost the same way except I just soldered it right to the pcb and used wire ties for strain relief. mine got way to hot wraped in electrical tape. when it eventualy shorted out at the other end I ditched it and rewired the "yo-yo" power supply from my old powerbook(G3) to work with my iBook(G4).
Mar 10, 2007. 1:06 AMwestfw says:
Ditto LasVegas's comment on using a vice. If you notice your cable just STARTING to fray near the exit from the wart, you can tape it to the wart early as a sort of additional strain relief. I've got a mac supply around here "fixed" like that; I'll see if I can get a picture...
Mar 9, 2007. 8:09 PMCameronSS says:
Step 4. Typo. "The core provides the ground and the outer cage acts as a ground." It doesn't work very well with only two grounds.
Mar 9, 2007. 8:01 PMLasVegas says:
You're missing Step 4.5: Connecting the wires. Also, I've found it most effective to use a Vise or C-Clamp to distort the case enough to break the glued areas, without damaging the remainder of the case. Tricloromethane (Plastruct brand, Plastic Weld) works well to re-bond the seams.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:reidab
