3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair A Powerbook AC Adapter
Step 3Get Inside
Get Inside
Now comes the hard part: getting the case open. I've seen suggestions of using a small screwdriver and a hammer. This might work fairly well to crack the seal. I didn't have a hammer, so I sawed away at the seam for a while and then pried around with a screwdriver. Experiment, pry, bend. Just get the seal around the outside cracked.
Once the seal is cracked, you still aren't quite home free because there's a metal shield inside that's glued to the top of the case. If you're pulling and it springs a little bit but doesn't open, get up under the shield with a screwdriver and gently separate it from the top. You can see the shield in image 2, below.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:reidab
