Repair a Tub Filler Diverter With Stripped Threads
2,426
24
5
Published
Introduction: Repair a Tub Filler Diverter With Stripped Threads
One of the washrooms in my house has a tub / shower with an old tub filler spout that was tiled into the wall.
Over time, the plunger that operates the diverter got stripped threads: it could no longer screw into the mechanism itself and we were not able to use the shower.
I tried gluing it with epoxy but this didn't work.
Using this method we were able to repair it.
Step 1: Measure
My idea was to replace the threaded section of the diverter with a new section of threaded rod.
The original threads were brass, I'm using stainless steel.
I measured the existing length of the plunger and tried a variety of threaded rods that I had, in order to get the correct size.
Step 2: Cut Off Damaged Threads
I cut the short section of damaged threads off the end of the plunger with a hacksaw.
Step 3: Drill a Hole in the End of the Plunger
I drilled a hole to the size recommended for the correct size tap I was going to use in the next step.
I used a small nail set to punch a divot into the end of the plunger so the drill bit would centre itself
Step 4: Tap New Threads
I tapped new threads into the newly drilled hole. The first time I did not drill the hole deep enough and the tap hit the bottom of the hole and destroyed the new threads, so I redrilled the hole much deeper and retapped.
I then screwed the section of threaded rod in as far as it would go, and marked it to cut off based on the lengths measured from the first step.
Step 5: Glue in Threaded Rod
I used epoxy to glue the section of threaded rod into the plunger.
I waited for that to dry and then screwed it into the tub filler body.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    5 Comments
    The only thing I would change here is to use threadlocker on your screwthreads otherwise nice fix
    Really helpful, thanks for the tutorial
