Repair a Keyfob - Failed
2,865
15
8
Published
Introduction: Repair a Keyfob - Failed
Here's an update about a month after fixing, my fix failed! Oh no. I'll leave the instructions steps that I followed and give a new step at the end.
From the original:
Take the paper clip or hairpin and shape in into a loop with the two long ends coming along side each other. Trim the ends to a length so that they fit onto the fob.
Make sure the loop is large enough to work with your key ring.
Step 1: Cut a Channel Into the Fob
I used the Dremel tool with an end cutting bit to make a channel in the plastic that ran from one end down to the panic button.
The channel needed to be long enough to fit the ends of the paper clip, and wide and deep enough for it to lay fully in the channel. Be careful not to dig all the way through the plastic casing in case you make contact with the components enclosed.
After digging the channel with the end cutting bit, I used the rounded engraving bit to smooth out the channel and work down any spots to ensure a good fit.
Step 2: Epoxy It Together
I used JB Weld because I had it handy from another project. I'm sure many other epoxies and glues would work.
Mixed equal parts of the two components and applied them into the channel, working it into the paper clip. When I was done I took a flat edge of plastic and wiped off the excess.
I let it cure in a warm place for about 5 hrs and then tested the strength by wiggling the eye loop.
I then fit it onto the key ring to ensure it worked well. I first tried this with the hairpin and found the eyeloop was too small. Then I tore it apart and redid it with the paper clip.
Step 3: Make It Look Pretty
Once I had a pin shaped correctly and I had confidence in the strength I removed the broken part of the fob.
I did this using a cutting bit on the Dremel and then smoothing the edges into a nice profile with a rounded engraving bit.
To finish it more you could sand the back and then apply some paint, but I was satisfied as it was so just hung them up and celebrated not spending money on a replacement.
Step 4: Have It Break and Buy a Replacement
Ha! This fix lasted 30 days or so. What could I have done better? Probably degrease the keyfob before using the epoxy for a better bond, use more epoxy to build up the amount of material remaining, and don't use a paper clip (it failed as well).
In the end I've purchased a keyfob cover from Amazon for $8. This is instead of the $40-60 for a whole new remote that light also need to be programmed by a locksmith. I don't know how well the cover will work.
Another alternative would be to 3d print a new case out of PLA or PVC.
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    8 Comments
    That's a pretty clever idea. I imagine you have to redo it every once in a while, but it should hold pretty well. It's just as good as getting it replaced if the replacements are just going to break too. I'll have to give it a shot. Thanks!
    http://www.brandysafe.com/auto.html
    hey I was just looking at this and I think I can help you.
    you should take apart the remote.
    File down a bit of the old fob so it looks nice and even, but still gives support.
    Get some wire.
    Drill wire sized holes in the old fob plastic.
    Bend your wire in half but not all the way.
    Stick the wire from the inside of the remote and pull it out.
    Cross the wires on the outside to a 180 degree angle (the wire is perpendicular to the remote)
    Trying to keep that angle, twist your câble 4 to 5 times (keeping the angle makes a nice twist)
    Make à loop with both pieces of wire and either twist it back down or solder it (without burning your plastic! )
    put thé remote back together and voilà!
    hope I helped :)
    This would definitely be worth a try. Thank you!
    I used lots of crazy glue and glued a blank key to the back of the fob and use the hole of the blank key to attach to my key ring. it lasted forever until I sold my camry.
    Very clever! I have a "panic button" on the back but I could have trimmed a spare key down to a size that wouldn't interfere with that with the Dremel. Next time I would try your method. Thanks!
    Yeah, now that you mention it I've never had an issue with other keys. I had also considered 3d printing a replacement or even making one out of wood. Good luck!
    I've never figured out why Toyota makes the hole so thin. Both of my fobs suffer from the same problem. I used some epoxy putty and formed a big ugly loop on one of mine. It's holding up well but looks hideous. I may have ot try your method for my other fob.
