Repair Leaked Water Dancing Speakers
35,686
18
15
Posted
Introduction: Repair Leaked Water Dancing Speakers
Hi, this is my first ible!
I bought these Water Dancing Speakers a year ago, and they worked great. But for some reason, one of the speakers broke, and the water inside it was emptied. I checked online for a solution but found no threads or instructions on how to repair them. So, if you're like me, I hope this helps!
Step 1: Tools You'll Need:
Here are the tools I used:
-An electric drill with a 1.2mm bit
-A syringe with a needle
-A philipps screw driver
-Epoxy/a waterproof sealant
Step 2: Disassemble the Speakers
Mine has 4 screws outside and 5 more inside. The board essily slid out and so as the transparent plastic part with the motor. The only part held down was the speaker. After removing the speakers, you can work more freely.
Just unscrew 2 more holding the motor in place and we're good.
Step 3: Refilling
I first drilled a hole 1.2 mm wide under the box. After drilling, I filled up the syringe, inserted it to the box, and than injected. It took me about 5 refills with my syringe. Just lay the other speaker(if it's not broken as well), beside the one you're fixing and use it as a guide.
Step 4: Sealing the Hole You Just Made
I sealed the hole with a two-part epoxy. You may use a sealant or caulk as long as it stays on and doesn't leak. Let it dry.
Step 5: Reassembly
NOTE:When reassembling, align the magnets on the rotor of the motor to the wheel's inside the transparent box.
I simply reassembled it after the sealant dried and you're good to go. Make sure you place all the parts correctly, because the lid might crack easily. They're still upside-down just to let the sealant dry more.
If you found this helpful, please vote for this. Thank you so much!
I hope this was helpful. Thank you!
2 People Made This Project!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
14 Comments
Hi cris. Great job! I'm a proud owner of the water dancing speakers too. I was wondering if you knew what type of plastic they are i want to resurface mine and Im not sure. I want to be sure before as to not compromise the speakers they are hard to find. Ty for your help
OMG 2 YEARS I WAS ON A HIATUS I'M SORRY I THINK IT'S TYPICAL ABS PLASTIC☹️
Any suggestions on how to fix this? Went to plus the speaker in and noticed the thing missing, opened it up to find it has come off. Can i glue it back on or is it broken?
One year late huhu I was on a hiatus for 3 years! Well you can glue it back however if it fails, I suppose you can find a replacement or just buy new ones☹️ But an adhesive will do the trick don't worry?
How to make a mp3 water speaker at home plz plz tell me
HEY! I just got back to Instructables with this account after years of doing nothing! Well it's fairly simple, all you need is an enclosure, speakers with a powerful bass, and a lot of water-proofing and leak proofs! I'll take it in mind and make one soon:)
can you take circuit pictures , i want to do that myself ;)
Where can I get A syringe with a needle
What liquid do you use to refill the speaker? Drink didnt workout...
