Introduction: Repair Computer Keyboard
Picture of Repair Computer Keyboard
Repair computer keyboard circuit using aluminium foil.
Step 1: Detect the Problem in Circuit Using Multimeter.
Picture of Detect the Problem in Circuit Using Multimeter.
Disassemble your keyboard by unscrewing all screws in the bottom. You'll see three plastic sheets. Clean any previous liquid spills or dirt.
  • upper circuit sheet
  • middle plain plastic sheet
  • bottom circuit sheet
Using multimeter, detect the fault in circuit. It may take a while in detection, be patient. Isolate the problem and this step is done.
Step 2: Using Aluminium Sheet As Conductor.
Picture of Using Aluminium Sheet As Conductor.
Use microwave aluminium sheet. I used shisha smoke foil. Cut a strip to cover the faulty area in circuit sheet.
Step 3: Placing Aluminium Strip With a Drop of Glue.
Picture of Placing Aluminium Strip With a Drop of Glue.
See the red circle. I placed the aluminium strip in between lower and middle plastic sheet. If you've isolated the fault correctly and placed the aluminium foil without a short. Your keys should work now.
Good Luck ~
seamster (author)2014-08-14
Nice trick, very useful!
About This Instructable
1,670views
18favorites
License:
Bio: Jack of all trades, master of none, though ofttimes better than master of one..
More by asrar1:Repair Computer Keyboard
Add instructable to:
