loading
DISCLAIMER - If you attempt to repair your own set, expect to void any warranty that might still exist.  If you do additional damage, it's your own responsibility.  Further, you are working with an appliance that is powered from you house mains.  There is risk of shock with the potential of death or serious harm.  Know what you are doing, and how to work safely with an electrical appliance.
Recently my 3+ year old 40" Samsung LCD TV started taking a long time to start up, with several cycles of relays clicking.  In searching the net I found that others were having similar problems.  Apparently, Samsung's power supply on several LCD models was somewhat under-designed, with four capacitors that slowly fail over time and which leads to the symptoms in the title.
There are several options for repair: 1) Take the set to a qualified repair shop (est $300 - $500). 2) Buy a new, replacement, power supply ($100 - $175). 3) Replace the offending capacitors ($4.00 - $15.00)
I chose option 3, spending $15.00 for a Samsung repair kit (contains 4-1000 uF, 25V, 105 degree C capacitors and "instructions").  If you want to keep the costs to a minimum, you can order an appropriate set of capacitors from Digi-Key or Mouser for about $0.65 each + s/h.
Tools you need:
Phillips screw driver able to reach recessed screws (about 1" deep)
Soldering Iron for general purpose electronic components.
Note: According to the Samsung repair kit instructions, this repair works with the following models:
LNT4042H
LNT4042HTX/XAA
LNT4053HTX/XAA
LNT4053HX/XAA
LNT4053HX/XAC
LNT405HAX/XAA
LNT4061F
LNT4061FX
LNT4061FX/XAA
LNT4061FX/XAC
LNT4061FX/XAP
LNT4065XF/XAA
LNT4066F
LNT4066FX/XAA
Step 1: Remove the back of the set
Place monitor face down on a cushioned table. Remove screws from cover and remove screws from the stand. (If stand is attached)
I have an optional wall mount setup, requiring removal of the wall mount hardware from the rear cover - a total of 4 screws.
Step 2: Disconnect and Remove the power supply
There are seven screws securing the power supply, as well as the various cable connecting to other components.  Remove the cables, remove the screws, and then lift out the power supply.
IMPORTANT NOTE - While capacitors are not particularly sensitive to Electrostatic Discharge (ESD), most of the components on the power supply and other boards ARE!  Take appropriate measure to avoid static discharge (grounding straps, etc.), or risk totally frying your set's electronics.  Should this occur, you're no longer facing an inexpensive repair.
Step 3: Identify, De-Solder, and remove the failing capacitors
There are four electrolytic capacitors to be removed: CM812, CM811, CM817, CS806.  These are clearly noted on both the front and rear surfaces of the power supply's circuit board.  (If you need a tutorial on how to de-solder "thru-hole" components, there are both text and video available on the net.)
You will likely see that the four capacitors of interest display bulging caps, and may even be leaking material.  On my set, only one showed any leakage, but all four were bulging.  The circuit they were used in is marked at 5.4V.  Based on my readings in electronics, capacitors should, in general, be rated for a voltage that is at least double the planned circuit.  Given that the original capacitors are rated at 10V, it would seem to indicate that fudging a bit here can lead to premature failure.
Step 4: Solder-in the replacement capacitors
The capacitors are polarized.  This means you MUST pay attention to the positive and negative leads on the capacitors.  The polarity is clearly identified on both the capacitors, there is a stripe down the side of a polarized capacitor with the minus sign, and the circuit board (both front and back indicate the polarity).  Failure to match polarity is BAD.  At the best, the capacitors will fail, in the worst case, they explode, and I assume, don't do anything good to the circuit board either.
Step 5: Replace the repaired power supply and attach the rear cover
Replace your newly repaired power supply, connect the internal cables to the other components.  Re-attach the rear cover, stand (if used), or wall mount brackets. Attach the external cables (Video, Antenna, etc.).  And, finally, plug in the power cord.  If all has gone well, press the power button and you'll see your set power up as it did when it was new.
NOTE:  The photo of my working TV is NOT representative of the image!  The horizontal striations are an artifact.
Step 6: Other Resources
You may find the following useful:
Samsung LCD Power Supply Repair Kit - BN44-00167A
Samsung Replacement Power Supply - BN44-00167F
Digi-Key - www.digikey.com
Hi, I was just given one of these, 40',. Same issue lol. Has a really nice picture when it's on. So I really want to fix it. Been doing a lot of research about the problem and have looked through lots of articles and videos but I like this post. Thanks for the posting it. I know its old but good info is good info! I wanted to ask if you or anyone else who may see this, know of a good place to order the caps? Also I noticed theres 2 fuses, I was thinking about going ahead and replacing those too while I'm in there, couldn't hurt, rt? OK, THANKS! again and please let me know if you know of any place.
<p>Hi Clyde,</p><p>For online purchases I use Digi-Key (www.digikey.com) and mouser (www.mouser.com). You will want to measure the diameter of the existing capacitors and check the lead spacing so you can order caps that will physically fit. Their voltage rating should probably be greater than the original 10V that were installed. </p><p>Bob</p>
I was just thinking they might be tied together is because they do it intermittently and how the power is cycling on n off. I know they are different and not the same circuits but wondered if the fast powering on n off could maybe cause it. As you can tell I'm no electronics expert lol. I was researching how to &quot;fix&quot; stuck pixels and some things I read made me think it might. Guess I'll take that on once I take care of the caps. Thanks for all the help!
Thanks! I was able to find them @ parts express. Also there were comments from people who used them for exactly the same thing. I did have another question; while dealing with this issue did you or anyone else notice any stuck pixels, sometimes when when the TV finally turned on? Sometimes when mine comes on I will have that but if I turn on and off a few times they will go away. I have a feeling it's connected somehow. And one more thing, I noticed 2 fuses so I was thinking about changing those to while I was in there. Any thoughts? Thanks again!
<p>The stuck pixels are unlikely to be associated with the capacitors - they are part of the power supply. The stuck pixels are likely to be somewhere in the video processor/display. Sounds more like a logic problem since they aren't always on. FWIW, I don't have any stuck pixels.</p><p>My thought on the fuses: Should be fine... If they'd failed, you'd have nothing showing, but if they're cheap... Your call. :)</p>
So I have a Samsung UN55B7100WF and I got the problem where the TV would click but wouldn't power on. After reading a lot of forms &amp; watching YouTube videos I though it could be a capacitor, because that seemed to be the most common problem. I took off the back and looked and the power board and all the capacitors looks fine. None were swollen nor had the top of the caps looking like they burst. Never the less I figured it could still be the board because some people say it could be hard to tell. I purchased a new board from PartStore.Com and it arrived today. About 20 minutes ago I took out the old board and installed the new board and hooked all the connections back up. When I tried to power it up the same thing happened. Click...click...click... never powering fulling up. No led showed or anything. So... The power board was a waste. It was about $173 after tax and shipping, and hopefully I get the majority of my money back. I did read it could be the TV board, but that is around $325 and if I am going to spend $600 in total I might as well just get a new TV. So all in all I didn't have any luck when replacing the power board. I'm still interested in what anyone thinks the problem could be if a new power board was put in and the clicking without it fully powering up could be attributed to.
<p>I also replace the power supply but nothing. It still didn't come on. Someone told me to replace the main board and it should work.</p>
<p>Did you find out what the problem was? I'm having the same issue.</p>
<p>GulfcoastCG,</p><p>I wish I could help. As I'm not an electronics engineer, your problems far exceed what little I do know. I understand your frustration, and like you, I would be looking to limit the cost.</p><p>Bob</p>
The set I have, LN-T4671F, was actually covered under a free replacement from Samsung. They were able to schedule a person to come out to my home and replace the whole power supply on my set the day after I called for support. It was only about a half hour to do the repair and I didn't pay anything. Comparing the two supplies, they actually had different value capacitors. I don't remember the values now, but the blown ones had lower values. I would recommend calling Samsung to make sure you're not covered before attempting this repair yourself. If you have to do this yourself however, thanks for this ible!
I'm glad to hear you were able to get Samsung to stand behind their product. I have to admit, given the age of my set, I didn't even think to call Samsung. There's always a risk with making assumptions! <br>Your observation that the original capacitors had lower values makes sense. The reports I've seen indicate the original power supply was populated with 10V max caps; the Samsung kit I purchased had 25V max caps. I would guess that's what the replacement board is populated with. As to replacing the entire board rather than just the failed capacitors, It's my guess that the cost of dropping in a replacement board (which likely costs only a few tens of dollars) is less expensive, and probably more foolproof than having someone de-soldering and replacing the failed capacitors.<br><br>bob
Hi bob i know its been a long time that you write this but i changed the capacitor and it didnt work so i notice a fuse marked t3.15a 250v which i found out was a slow blow fuse. I changed the fuse for what i thought was the same but it was mark down has anti surge fuse but was marked t3.15a 250v this fuse blow apart. So not sure it was the fuse or there is another problem.any help would be great peter<br>
<p>Peter,</p><p>I wish I could offer help, but I'm not an electronics engineer. Unfortunately, the problems you're describing far exceed my knowledge and experience.</p><p>Bob</p>
<p>I guess I will try to fix it myself. Had hoped Samsung would have stood behind their defective product.</p>
<p>The repair is relatively simple, assuming you have some dexterity with a <br> decent soldering iron. If you don't have experience soldering electronic components, perhaps you could enlist a friend's help??? I wouldn't tackle this as a first time soldering project; it will be very frustrating and carry an elevated risk of failure. Best of luck! :)</p><p>How long ago did you purchase the set? Most consumer electronics have a 90 day warranty, sometimes up to a year, but I don't think I've ever seen longer. The basis for those warranty terms is that electronics, in general, fail very quickly if defective. When I posted this four years ago my set was already long out of warranty. Ultimately, the problem was due to widespread distribution of poorly manufactured capacitors, the manufacturers of the end user products had no way of knowing they had purchased defective parts. The problem affected many manufacturers and products. </p><p>More information can be found here: </p><p><a href="http://en.wikipedia.org/wiki/Capacitor_plague" rel="nofollow">http://en.wikipedia.org/wiki/Capacitor_plague</a></p>
<p>Thank you for your thorough and clear Instructable! I had the same problem, but with a different Samsung model. Working fine now. Thanks to you, we will be able to watch the Notre Dame vs. Florida State football game tomorrow! Go ND!</p>
<p>Thanks!.. I Made it.. Although my TV is not listed on the Models sown above it had exactly the same problem. Mine is an LN40A450C1XZL</p>
Glad you found the information useful!<br><br>Bob
Digi-Key no longer sells the repair kit, btw.
IF YOUR SAMSUNG TV STILL HAS NO PICTURE AFTER THE CAPACITIORS ARE REPLACED READ THIS. <br>TV model is LN46A540P2FXZA 3.5 YRS OLD no picture but we have sound. <br>SHORT VERSION <br>1. replaced the bulging capacitor and the one next to it. NO PICTURE. <br>2. Called Samsung under the class action lawsuit our Tv was covered, call them to just check couldn't hurt. <br> <br>3. TV repair came out twice first replaced the same 2 caps that we had replaced prior, still no picture but we knew that. Came back with a power supply board and replaced it, still no picture. These are the 2 things that were authorized by this lawsuit to replace, that's it and we got both. <br> <br>3. Then we went to ShopJimmy (I have nothing to do with this site) purchased 2 inverter boards found the place online and the information by reading a lot. <br> <br>Remember this is the short version. From everything we read online the suspect was probably the back light we replaced the right and left side inverter boards. and the parts added up to less than $45.00 including shipping which was free. <br> <br> Ordered online on a Sunday and we had the parts by Wednesday, took the tv apart and replaced the 2 inverter boards located on our model on the left &amp; right side. The hardest part about this repair is taking it all apart and putting it all back together again, the inverter boards snap in where the old ones snap out of and they came out pretty easy. We put it all back together and plugged it in and we have ONE BEAUTIFUL TV PICTURE AGAIN!!! <br>Inverter boards (on our model) are located under a piece of sheet metal so you have to take that off first. <br>
these are the parts we replaced for the last and best fix if I can get them to load on this site.
From sstiefel on another page. <br> <br>&quot;I called Samsung. There is some settlement on some brands of Samsung LCD TV's sold before 2008. I spoke to a nice lady at 888-899-7602 who asked for my model number and serial number, then took my info to arrange for a local repairman to come by within 1-2 days to check the capacitor and replace the power components at no charge. SO glad I read this page and called Samsung before having it shipped off and spending a lot of money. Hopefully I will get extended life from this TV set with this servicing.&quot; <br> <br>I called and got a tech to come out for free!
Good information. Thanks for sharing it.<br>FWIW, my repair seems to be holding up so far.<br><br>Bob
Thank you so much for this! I have an LNT4061F. I replaced two of the capacitors, both 2200uF. They had different numbers on the board, but both had bulging tops. The originals were 10V, and I replaced them with 25V.
Sounds like a reasonable approach.<br><br>When mine failed, I assumed it was due to some design error/failure on Samsung's part. But, in the interim I found that the &quot;Bad Capacitor&quot; tale has a much broader impact, and was far from limited to just Samsung's TVs.<br><br>http://en.wikipedia.org/wiki/Capacitor_plague<br><br>Bob
This guide helped me. My TV has been doing this for a year. I've been putting off fixing it because it was easier to wait for it to turn on than risking breaking it completely. Until yesterday when we turned it on before I left for work and when I came home some 9 hours later and it was going click clack (never took more than 2 hours to turn on before). <br><br>Unfortunately none of the local stores had the needed capacitors. Also I found what the TV had was two 1000 &mu;F 25v 105C capacitors and two 2200 &mu;F 10v 105C capacitors, not four identical 2200 &mu;F 10v 105C capacitors. All of them were bulging and/or leaking. I found and old mother board laying around, which had a bunch of 1500 &mu;F 16v 105C capacitors. They were the closest thing I had so I took four from there and put them. What do you know, it worked.
Cool! Good to hear.
I just scored a free LA46N81BDX with click-of-death from a friend who used the fault as an excuse to upgrade. There were two blown 10v 2200uF 105degC capacitors. Replaced them for total cost of $2.20 and it's working perfectly!
Glad you saved the $$$ and that the instructions made some sense...<br><br>bob
Never mind! I just saw the model numbers! :-)<br><br>Kudos!<br><br>K.
K.,<br><br>Thanks for the feedback! After reviewing what I did, I realize there are a couple of edits I want to make (adding a couple more web references on soldering, parts sources, etc.). <br>I wish the photos were of better quality. I've got a Canon Powershot SD30 with a crushed LCD that I've not yet repaired (I think I found the repair instructions on this site - don't quite remember); so, I was shooting &quot;blind.&quot; So it goes... :)<br><br>Bob
Excellent instructable. If you put the model name of your TV on the title then millions of people suffering from the same issue will be able to locate your excellent work. Believe me, you will receive many thank you messages. Cheers, K.
About This Instructable
297,160views
36favorites
License:
Bio: Having experienced a somewhat checkered career path, I've landed in the ICU as a nurse. Formerly a software engineer, building contractor, professional photographer, SCUBA ... More »
More by nursebob3428:Repair Samsung LCD TV -Relay Clicks, Shuts Off, Won't Come On
Add instructable to:
