Recently my 3+ year old 40" Samsung LCD TV started taking a long time to start up, with several cycles of relays clicking. In searching the net I found that others were having similar problems. Apparently, Samsung's power supply on several LCD models was somewhat under-designed, with four capacitors that slowly fail over time and which leads to the symptoms in the title.
There are several options for repair: 1) Take the set to a qualified repair shop (est $300 - $500). 2) Buy a new, replacement, power supply ($100 - $175). 3) Replace the offending capacitors ($4.00 - $15.00)
I chose option 3, spending $15.00 for a Samsung repair kit (contains 4-1000 uF, 25V, 105 degree C capacitors and "instructions"). If you want to keep the costs to a minimum, you can order an appropriate set of capacitors from Digi-Key or Mouser for about $0.65 each + s/h.
Tools you need:
Phillips screw driver able to reach recessed screws (about 1" deep)
Soldering Iron for general purpose electronic components.
Note: According to the Samsung repair kit instructions, this repair works with the following models:
LNT4042H
LNT4042HTX/XAA
LNT4053HTX/XAA
LNT4053HX/XAA
LNT4053HX/XAC
LNT405HAX/XAA
LNT4061F
LNT4061FX
LNT4061FX/XAA
LNT4061FX/XAC
LNT4061FX/XAP
LNT4065XF/XAA
LNT4066F
LNT4066FX/XAA
Remove these ads by
Signing UpStep 1: Remove the back of the set
I have an optional wall mount setup, requiring removal of the wall mount hardware from the rear cover - a total of 4 screws.
Visit Our Store »
Go Pro Today »
TV model is LN46A540P2FXZA 3.5 YRS OLD no picture but we have sound.
SHORT VERSION
1. replaced the bulging capacitor and the one next to it. NO PICTURE.
2. Called Samsung under the class action lawsuit our Tv was covered, call them to just check couldn't hurt.
3. TV repair came out twice first replaced the same 2 caps that we had replaced prior, still no picture but we knew that. Came back with a power supply board and replaced it, still no picture. These are the 2 things that were authorized by this lawsuit to replace, that's it and we got both.
3. Then we went to ShopJimmy (I have nothing to do with this site) purchased 2 inverter boards found the place online and the information by reading a lot.
Remember this is the short version. From everything we read online the suspect was probably the back light we replaced the right and left side inverter boards. and the parts added up to less than $45.00 including shipping which was free.
Ordered online on a Sunday and we had the parts by Wednesday, took the tv apart and replaced the 2 inverter boards located on our model on the left & right side. The hardest part about this repair is taking it all apart and putting it all back together again, the inverter boards snap in where the old ones snap out of and they came out pretty easy. We put it all back together and plugged it in and we have ONE BEAUTIFUL TV PICTURE AGAIN!!!
Inverter boards (on our model) are located under a piece of sheet metal so you have to take that off first.
"I called Samsung. There is some settlement on some brands of Samsung LCD TV's sold before 2008. I spoke to a nice lady at 888-899-7602 who asked for my model number and serial number, then took my info to arrange for a local repairman to come by within 1-2 days to check the capacitor and replace the power components at no charge. SO glad I read this page and called Samsung before having it shipped off and spending a lot of money. Hopefully I will get extended life from this TV set with this servicing."
I called and got a tech to come out for free!
FWIW, my repair seems to be holding up so far.
Bob
When mine failed, I assumed it was due to some design error/failure on Samsung's part. But, in the interim I found that the "Bad Capacitor" tale has a much broader impact, and was far from limited to just Samsung's TVs.
http://en.wikipedia.org/wiki/Capacitor_plague
Bob
Unfortunately none of the local stores had the needed capacitors. Also I found what the TV had was two 1000 μF 25v 105C capacitors and two 2200 μF 10v 105C capacitors, not four identical 2200 μF 10v 105C capacitors. All of them were bulging and/or leaking. I found and old mother board laying around, which had a bunch of 1500 μF 16v 105C capacitors. They were the closest thing I had so I took four from there and put them. What do you know, it worked.
bob
Your observation that the original capacitors had lower values makes sense. The reports I've seen indicate the original power supply was populated with 10V max caps; the Samsung kit I purchased had 25V max caps. I would guess that's what the replacement board is populated with. As to replacing the entire board rather than just the failed capacitors, It's my guess that the cost of dropping in a replacement board (which likely costs only a few tens of dollars) is less expensive, and probably more foolproof than having someone de-soldering and replacing the failed capacitors.
bob
Kudos!
K.
Thanks for the feedback! After reviewing what I did, I realize there are a couple of edits I want to make (adding a couple more web references on soldering, parts sources, etc.).
I wish the photos were of better quality. I've got a Canon Powershot SD30 with a crushed LCD that I've not yet repaired (I think I found the repair instructions on this site - don't quite remember); so, I was shooting "blind." So it goes... :)
Bob
