Repair Stripped Screw Holes
22,248
26
8
Posted in WorkshopWoodworking
Introduction: Repair Stripped Screw Holes
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    8 Comments
    I use wood golf tees, works great!
    Bamboo skewers work the best as the fibers run one direction. I use them when door hinge screws wont hold.
    Use a Rawlplug theyr made for the job.
    They come in different sizes to suit the screw.
    The problem with matches or toothpicks are two-fold. First, they strip themselves, fairly quickly (or perhaps shred would be a better description). And second, they put a lot of sideways pressure on the wood, and can cause it to strip.
    A better fix is to drill out the hole with a 1/4" bit, put some glue on a length of 1/4" dowel, and hammer it in. When it's dry, cut it flush (you do have a flush-cut saw, don't you?) and drill a new pilot hole for the screw.
    This: "they put a lot of sideways pressure on the wood, and can cause it to strip"
    was supposed to be "can cause it to split".
    Toothpicks, etc., can make an easy, fast fix, but they'll strip themselves, in a couple of years, and if you keep jamming in more you can split the wood.
    It wasn't until the third time of having to go back to the same door, after having "fixed" it with toothpicks, that I got fed up and went with a permanent fix.
    And for this sort of problem, the fastest permanent fix is to dowel it. It doesn't take but a few seconds, if you have glue, drill, and dowel on-hand.
    Another fix is to fill the hole with steel wool and then drive the screw back in.
    I don't bother with glue -I just shove in a wooden match and that seems to do the trick.
    This is actually a fantastic idea! I've done it my self from time to time! It works like a charm and holds really well.
