3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair Stuck Lens on Panasonic FZ5
Step 2Disassembly: Housing
First remove the lens cap lanyard, any straps, the battery and the memory card.
The first fixing to remove is an allen bolt under the flash. This, along with six screws distributed around the main seam, secures the back to the front of the camera.
Remove all six screws too, and note that three are long, three are short, and both types have different threads. You're now ready to get inside this thing...
5 comments
May 2, 2009. 2:59 PMsoulmisfit says:
I used white out to mark when necessary.
Nov 18, 2008. 10:12 PMboeger says:
I have a DMC-FZ7 I was able to remove 3 screws and it looks like there is some blue loctite on them. The others are putting up a good struggle and I don't want to shred them. Is there a way to get around the blue loctite?
Nov 19, 2008. 8:16 PMboeger says:
ah, i solved it. i heated the screws with a soldering iron for a few seconds and they were much easier to loosen.
Jan 15, 2008. 6:17 PMArkAdmin says:
There are 3 longer screws with coarser threads and 3 shorter screws with finer threads. The two screws on either side of the bottom camera mount are long coarse-thread screws. The other screw on the bottom of the camera is a short fine-thread screw. The screw by each shoulder strap bracket is a short fine-thread screw. The last screw by the battery and memory card slot is a long coarse-thread screw.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:Nachimir
I live in the UK, and work for a games consultancy. I used to take my toys apart and put them back together when I was a kid, nowadays I try to do the same with emotion, motives and culture. I also...
more »
