Step 3Disassembly: Ribbons and Cables and Screws. Oh My!
The back section, which holds the LCD and some of the controls, is connected via two ribbons and two power connectors (labelled in first photo below). The ribbon connectors have fasteners at either side that slide along the same plane as the circuit board. Gently slide them out, and you'll be able to (carefully!) remove the ribbons.
The power connectors are a little trickier; work them gently, don't yank no matter how tempted you are. Working a slim object such as a screwdriver blade between the connector and the socket may help, but make sure not to abuse the connection between the socket and the circuit board.
Now you should be able to remove the back of the camera.
comments
Add Comment
Add Comment
