Step 5Disassembly: Final Steps
Two of the parts shown below are secured to the inside of the camera in a rather rickety fashion. The lens is very solidly fastened in place of course, but the AF/EVF assembly and the lens motor are not. They're also made of fairly soft plastic. The lens is stuck because of these flaws.
First, remove the single screw that secures the AF lamp and electronic viewfinder assembly, shown in the first image below. Then remove the two black screws that keep the lens motor in place, highlighted in image number two. Do not pull on the lens motor, it will still be fixed to the lens assembly by the ribbon you can see stretching across it.
Next, remove the screw near the base of the camera, highlighted in the third image of this step. This is the final fixing that secures the lens assembly in place, so slide it gently out of the back. You have now dismantled the camera far enough to fix it.
comments
Add Comment
Add Comment
