Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
My LCD ribbon was very worn and open circuit so i removed the ribbon carefully from the PCB end and trimmed it back using a scalpel and ruler so i had a clean ribbon. You must make sure you have enough ribbon length to do this. Also clean off any old LCD ribbon debris from PCB pads.
Then to re-apply use the hot glue gun and tinfoil method but only tack down one end first of the ribbon to the PCB to get good alignment. You can check alignment with magnify glass. Then tack down the rest.
I used the hotair tip for my Portasol gas soldering iron as the heater. It is perfect for the purpose.
I captured the steps in these 4 images.
If you are interested in complete professional information on how to repair LCD televisions, please be sure to check out this link: http://unique.octopis.com/LCD_Repair.htm
Just used it to repair my Sharp Calculator!
I filled the screen with 8s and did a calculation to fill all of the display elements. I ran my finger nail along the connection to see which part of the ribbon affected what part of the screen so I knew where to iron each time.
i got a hole bunch of them and they are broken up abit, mostly buttons and all the lcd screens are busted so i wanted to fix them
I did have to heat the ribbon up three times to get the 95%. I didn't know how hot to get it or how hard to rub. Each time I would stop and then plug the battery back in to check then unplug and try again. I'm sure four times would have been the ticket.
Awesome instructable.
Thanks.
Many thanks!
Valyntyn
B.C. Canada
I will try it into two philips cordless phones.
