3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair a Window Screen on the cheap
In your home or apartment, you may have a window whose screen has a small hole in it. Here's a very quick and cheap way to prevent the bugs and tiny critters from gaining entry!
Step 1Cut some transparent tape
As a disclaimer, I've only done this with very small holes in a window screen. I'm not sure if it would work well for holes greater than 1"x1". That being said, gather your supplies:
  • transparent tape (scotch tape or packing tape) whose width is at least as wide as the hole
  • window screen removed from window for easy access
  • scissors
Use a pair of scissors to cut a neatly-trimmed square or rectangle of tape that is big enough to cover the hole on one side. Then cut a second piece exactly the same size.
Place one piece of tape over the hole in the screen and press firmly. Depending on whether the screening material is metal or fiberglass, the tape won't stick very well, but that's okay! We're not done yet.
Flip over the screen and apply the second piece of tape to the opposite side. Now press the two adhesive faces against each other at the location of the hole.
Pardon my craptastic GiMP illustration: the black lines representthe screen with a hole in it (the gap) and the blue lines represent the two pieces of tape "meeting" at the site of the hole.
The tape doesn't have to stick to the screen, just to itself.
4 comments
Jul 16, 2008. 7:01 PMRyanPotter says:
Not a bad idea, but I think it would look nicer and last longer if you took a needle and thread and basically made a little screen by stitching it over the hole.
Jun 2, 2009. 8:52 PMgregr says:
Rather than making a screen by stitching over the hole try cutting the hole in the screen into a perfect rectangle then cutting a piece of replacement screen the same size as your rectangle and just sew the edges together. Superglue would probably also attach the patch to the rest of the screen.
Jul 17, 2008. 12:20 PMScott_Tx says:
For larger holes just substitute with clear packing tape. I've used it to fix cracked windows too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Kozz
A programmer ever since I laid my hands on a TRS-80 writing BASIC programs like mad-libs in 1990. Goes back to 1984 if you count my trance-like state induced by a PET computer. Now I get paid to do ...
more »
