Repair an Exposed Wire with Sugru by Carleyy
Featured
The black casing on laptop charger cord broke and I could see the inside wires.  When this happened to my last charger it broke soon after.  Sugru is a great way to cover up these wires and keep my charger safe and working!
Step 1: Exposed Wires
I am constantly bending and wrapping the cord and throwing it in my backpack.  It if only a matter of time before the white and green wires broke as well.
wil2ya says: Sep 23, 2010. 9:23 PM
I would use shrink tubing . It comes in many sizes .You heat it and make a
durable & waterproof seal .
rkrishnan7 says: Sep 24, 2010. 8:04 AM
Heat shrink tubing of a diameter large enough to thread past the end connector would not shrink down sufficiently to have a firm wrap around the area.
Maybe you have a solution to the problem ?
pfred2 says: Oct 20, 2011. 9:29 PM
Then split insulation off another piece of wire put it around the compromised wire, and shrink wrap over all of it. Still a better fix than this nonsense.
wil2ya says: Sep 24, 2010. 2:45 PM
I' d use a good grade of electrian's tape or when it happened
to my ear buds I used some PTFE thread sealing tape that
plumber use , it sticks to itself and isn't messy Wil
wetnap says: Jul 25, 2011. 3:48 PM
Epoxy putty from the local hardware store is cheaper I bet. Also the bond would be stronger, you could put a decent wad of epoxy putty around that and it would provide cord strength through adhesive power, I think sugru might have less bonding strength since ive seen folks peel that off. Putty isnt flexible but that is ok for a small segment, just put a small mound of it on.
honorman says: May 8, 2011. 1:44 PM
You can buy at auto parts place a blue (maybe other colors ) coating made for coating tool handles, I use it for insulating wires and tools handles, great stuff
hairybaroque says: Sep 23, 2010. 8:37 AM
This is very interesting, but what is Sugru? We don't have it in the UK and I assume it's something you mix by kneading, like epoxy metal? I'd hate to use the wrong stuff and explode something!
pmsfo says: Apr 26, 2011. 11:17 PM
According to wikipedia, Sugru was developed right next door to you there in the UK. It is an Irish invention. http://en.wikipedia.org/wiki/Sugru
StuNutt says: Sep 23, 2010. 10:24 AM
Obviously the "owners" of Instructables know what Sugru is - they have a "Sugru Competition" (just see the links to the right of the page!)
I must admit that this Brit had never heard of it either - must investigate!
ericfrog says: Sep 23, 2010. 9:12 AM
I live in the UK as well and had never heard of it before this post but a quick web search showed me that is available here and sounds interesting.
I've just ordered 12 wee packages for £11.74 delivered to my door, so will comment no further until I've tried it...
jessyratfink says: Oct 5, 2010. 4:50 PM
Ha! I was actually going to enter the same thing! Good thing I checked beforehand. My apple cords always fray. :)
benjabean1 says: Oct 1, 2010. 8:12 PM
Can you still bend it?
Sergei- says: Sep 25, 2010. 2:54 AM
That looks too thick and stands out more then you would like
If you use heat shrink you need a peace that will fit over the connector sometimes impossible to shrink over the cord in that size or you need to cut the cord but seriously who would want to cause damage to fix something minor
If you use electrical tape soon it will unstick and get dirty
If you use the good old classic duct tape it won't be flexible enought
The best i have found is called rescue tape for almost everything you can throw at it
Google it and be amazed of what it can do
knektek says: Sep 25, 2010. 6:45 AM
Use AT, Aluminum tape. Only if the wires arent both exposed, it could cause a short -_-....
CoolKoon says: Sep 26, 2010. 3:16 PM
Remember, this is INSULATION. The replacement of any insulator with some conducting tapes for whatever reason is asking for trouble.
Arathefu says: Sep 26, 2010. 9:44 AM
Um, well, it's good if you try it when cord is still working, but once it starts to breaking circut it's hard to fix it that way (and that's when usually you find out there's a problem). Anyway - good instruction :)
and-reas says: Sep 25, 2010. 10:22 AM
You have the exact same adapter for a Dell laptop as I have. And the exact same problem on the exact same place.
They said it wasn't covered by the warranty, so I used your little I'ble to do it myself, thanks =)
anode505 says: Sep 23, 2010. 5:06 PM
Hate elect tape for this type thing. heat shrink works better. can grt marine grade that has an adhesive internally for better sealing
awfeckit says: Sep 23, 2010. 12:17 PM
duct tape
Holds the world together.
bgray1009 says: Sep 23, 2010. 9:02 AM
Great idea! The Sugru will make it stay flexible and strengthen it too(long live sugru), oh btw hairybaroque sugru is available in the UK and has been for some time, i use it regularly,it is not mixed it comes pre made
pizzaboy192 says: Sep 23, 2010. 8:36 AM
Ever heard of Electrical tape?
Yeah... works wonders. And it's flexible... and it's the same color as the cord...
I built a 18 foot power block for a 90W dell power brick using electrical tape and some time. not too hard.
carpespasm says: Sep 23, 2010. 7:37 AM
I'm a big fan of hot melt glue in these cases.
bongodrummer says: Sep 23, 2010. 6:34 AM
Great. So tell me, how bendy is it with the sugru? Will, for example, it suffer from the same problem at the tip of the sugru, or dose it flex enough that this is not a problem? Interesting stuff...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
