Repair and Restore Masterbuilt Electric Smoker
5,662
19
Posted
Introduction: Repair and Restore Masterbuilt Electric Smoker
Learn to RESTORE your Masterbuilt 20070910 30-Inch Electric Smoker to working and like new condition.
While this Instructable is specific to the Masterbuilt brand and model mentioned, it might be able to be used as a guide for other brands and models. Read on to see the problem and solution with this smoker.
With a few tools and a few skills you can get your smoker up and running again to smoke your favorite meats.
Cost for restoring electrical circuit was only a few dollars for male and female connectors.
This is my first smoker. I have been nothing but happy with it's workmanship for several years until this past winter. This past winter I noticed that the smoker would trip the GFCI circuit in my garage after only being powered for a minute or so. My first thought was there was just too much of a load on that circuit with all the other stuff powered in the garage. So, I proceeded to use the GFCI off the deck area of the house. This worked for one more smoking session, then I had the problem again. Since the second circuit had no load on it besides the smoker, I knew something had to be wrong with the smoker.
After some research I surmised that there was a faulty connection between power source/supply and heating element. There was also some mention in online research that the heating element itself might just need a really good cleaning. Click Here to do your own research on this problem with this brand and model.
The problem was exactly that. A corroded connection where wires connect to the heating element.
Read on to see how to restore your faulty wiring and connection as well as clean the element.
Step 1: Tools and Supplies
  • Screw Drivers
  • Pliers
  • Wire Cutters and Strippers
  • Wire Brush
  • Steel Wool
  • Propane Torch
  • Rotary Tool
  • Rotary Sanding Drum
  • Solder
  • 14-16 Male Connectors
  • 14-16 Female Connectors
Step 2: Cause of Problem
I suspect the cause of the corrosion was due to a combination of moisture coming from the smoking process when using the water pan and smoking meats out in the rain.
Compare the images and you will see the corroded male spade terminal. After removing the heating element I was able to easily snap this connection with my fingers. This was the cause of the GFCI tripping. Thank goodness for building codes and GFCI. This could have been a potential fire hazard without the GFCI protection.
Let's move on to fixing the problem.
Step 3: Inspect Heating Element Connection
To inspect electrical connect start at the outside back of unit and find the access panel.
  1. Remove screws
  2. Remove panel
  3. Inspect connections
Depending on the condition of the wires the wires should pull away from heating element connection.
See the 2nd image and you will see the connection is quite corroded. In fact, when I tried to pull the wire the connector at the heating element snapped. The connection at the right pull off with a pair of pliers and just needs some cleaning.
Step 4: Remove Chip Box
Ah... look at the evidence of smoked meats! You can almost smell those ribs smoking just looking at the pictures.
Before you start working... be sure you smoker is unplugged.
You will need to remove the wood chip box and ash trap from the inside of the unit.
  1. Remove ash tray
  2. Remove screws that attached chip box to inner wall
  3. Remove nut and bolt that attach box to lower support
  4. Remove chip box.
  5. Heating element is now exposed.
Step 5: Remove Heating Element
Removing the heating element is now relatively simple after wires are disconnected including ground wire.
  1. Disconnect wires.
  2. Remove mounting screws.
  3. Remove grounding wire nut. (this was done before picture was taken)
  4. From inside of unit remove grounding screw. In the last image it is covered I smoker grime in center of two heating element probes.
Your heating element will pull out easily.
Step 6: Clean Heating Element
With some steel wool and wire brush clean your heating element.
Step 7: Remove and Restore Corroded Connection
Now lets restore that bad connect to like new condition.
  1. Use a propane torch to heat up the solder connection between connector and heating element.
  2. As you are heating use pliers to pull off the old connector.
  3. Use rotary tool sanding drum to give it a good clean.
Step 8: Replace Heating Element Connector
Using 14-16 awg male connectors, solder a new connector to the heating element. Since only one of my connectors was in bad connection I replaced one. Your call if you want to replace both.
Sorry... no images of the soldering process as I only have 2 hands to work with. :-)
Step 9: Replace Female Connectors
Using a combination of male and female 14-16 awg connectors, replace all connections that are in bad condition.
Step 10: Reinstall Heating Element
  1. Reinstall heating element and screws
  2. Connect wiring
  3. Cover Panel
Step 11: Reinstall Wood Chip Box and Ash Pan
Reverse the steps previously explained on uninstalling the wood chip box and ash tray.
Step 12: Pack and Smoke
Pack your smoker with favorite meats and smoke 'em!
As mentioned earlier cost for restoring the circuit was only a few dollars for new connectors. Before tackling this project I check cost of new smoker. This smoker retails between $150 and $250. Amazon currently has on sale for $150 with some minor upgrades in design.
YADI
Made By DIS Maker
MyWlakeTech
That's right... the teacher of MyWlakeTech jumped in on the fun of an Instructable as well! Why should the kids have all the fun.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    I have sportsman elite smoker, Have problem with it shutting down after about a hour all lights go off. Can hear clicking noise from digital display keeps shutting office restarted. Any ideas what it might be????
