Repair modular power supplies
Instructions on how to break the seal on modular power supplies to fix the common problem of fatigue breaks in the cord, repair the internals, or salvage for other uses. This will violate warrantees so do this only for equipment not covered by one. Pardon the pics, I don't have a camera for this.
Step 1The modular power supply
These come in all shapes and sizes and capacities. The arrows point to the common point at which the cord tends to break internally. Before opening it, be sure that the power supply itself is at fault, and not what it's plugged into. If you are just salvaging, this can make good practice for when you are repairing one you intend to re-use.
20 comments
Aug 29, 2010. 3:06 AMskyd123 says:
Thanks a lot for this article.. Going to try this as soon as i reach home.. Its three weeks w/o my laptop... Thanks again ..
Nov 15, 2009. 1:40 PMadvancedage says:
Thank you! After my sister swung the cord around I've been without a laptop but today I got bored and found this article. Now I just need to do a little soldering and I use it again. Hurry!
May 23, 2009. 10:28 AMmanumanu says:
This guide is very very useful... I experienced the very same fault of the power cord, just near the relief and I after reading this I'm surely going to try to fix it. Thank you all. Bye from Italy
Aug 27, 2008. 12:09 PMDerin says:
I would like to rent that space,for $0
May 11, 2008. 4:36 PMValche says:
I doubt I'll be taking power supplies apart any time soon, but wow, what a detailed instructable! Very good work, and I never knew that that's how some cases are sealed, good to know! Great stuff. +1
May 31, 2006. 2:42 PMpwilliam56 says:
Most of these can be saved this way. Great information. I have found that most of these cases can be opened fairly easy by placing them on a smooth, hard surface (concrete or tile,) with the seam perpendicular to the floor and the case on one edge. Take a hammer and carefully tap on the top edge of the seam. With a little practice the shock of a well placed tap will pop the glue loose. Sometimes it is necessary to turn the case over and tap on the opposing corners to break the seal all the way around. This generally doesn't scar up the case as badly as just prying it apart.
Jun 6, 2006. 5:38 AMpellepeloton says:
Sometimes you may have a faulty transformer and often is is the primary/ Just check with multimeter between the pins on the AC plug. If you have an open circuit, you may still be able to salvage it as there might be a thermal fuse or normal fuse inside?
May 30, 2006. 4:08 PMspinach_dip says:
How dangerous is this?
Dec 17, 2006. 4:05 PMxcursedx says:
to many outer cases won't come unglued, so i just glue then tape them up, i also find it's better to shave down to the wire then to cut into it, i just replace the jacket with a piece of wire housing, usually the thickest i have around, i also usually lead the wire up [__].| from the housing to reduce future stress...
May 30, 2006. 9:53 PMjtobako says:
a strip of electrical or duc tape will extend the strain relief and reduce the number of times you have to re-do the repair.
May 29, 2006. 9:15 AMrjones3 says:
Nice work on the drawings!
Jun 1, 2006. 1:43 AMVermin says:
Another method for opening the case is to squeeze the seams gently in a vice. I've used this to pop many a case open without fail.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Prometheus
jack-of-all-trades hobbyist/inventor/fabricator Specialties in automotive. cycling, power-transmission (electrical and mechanical), old-school fabrication/tooling.
