3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair modular power supplies
Step 3The guts
The guts
This is an overly simplified look at what's inside. DC power supplies can be simply a diode and a capacitor, or could have a full regulation circuit. AC power supplies will at best have a small disc capacitor, if anything, making the DC variety more suitable for projects/modification. Double-check the transformer to see that you didn't accidentally chisel the windings.
Look at the transformer spool (in yellow) to look for overheating/burning, distortion, or other deterioration. This will likely indicate the transformer had overheated. You can test for transformer output by plugging it in on a switched outlet, with only the top half removed. Leave the assembly in the wall-side half so that you can pull it out again without damaging the unit.
WARNING:
No matter what you use any part of the power supply for, never plug the bare transformer into the wall or any fault in the transformer can result in severe shock.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Prometheus
jack-of-all-trades hobbyist/inventor/fabricator Specialties in automotive. cycling, power-transmission (electrical and mechanical), old-school fabrication/tooling.
