Step 9: Reassemble the click mechanism and test
At this point, before reassembling the mouse, set it down on the table, and give the tiny white button a few test clicks. You should notice that it is making a crisp click sound when pressed, and that it now springs back with more force than it did before. If you are not hearing and feeling a difference, you may need to open the mechanism back up and try retentioning the spring again.
If all seems well, than go ahead and put the mouse top back in place, reinstall the 4 main screws, and put the slide pads back in place. If there is not enough adhesive left to keep the slide pads on, you can add some more. Regular elmers glue stick has worked for me, or a dab of superglue would certainly do the trick.
Thanks for reading. I hope you now have a mouse that clicks properly.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
I've a Logitech V450 Nano Cordless Laser Mouse which started to "double click" after 3 years, and the Logitech Support told me "Unfortunately, we must inform you that your product is defective, as at the moment the manufacturer warranty is already expired, I will not be able to replace the product for you. Unfortunately, there is nothing I can do to help you with your case." So I started googeling without any success, everybody was talking about windows settings, but this was a mechanical issue, and now its working flawless. Thanks again, Best Regards ;)
One tip on this step. If you don't want to turn the mouse upside down, you can put a piece of clear tape across the top of the click mechanism cover (part that says "omron") so it holds the white button in place. Then even trim the tape so it doesn't stick out too much. Then you can keep the mouse base steady and right side up as you carefully slide the click mechanism cover back on top and snap it in. Then remove the tape. This is the only thing I did differently. Another tip, if you have a digital camera handy is to take a picture of the spring before you remove it so you have a reference. It fits in very delicately and its easy to lose track of the exact position if you don't have a reference. Your pictures are wonderful but its handy to have one specific to your mouse in case it differs slightly. Thanks again!
