Repair of Broken Laptop Hinges and Cracked Top Cover
Introduction: Repair of Broken Laptop Hinges and Cracked Top Cover
I have a laptop Acer Extensa 5620 that is still useful for me, but its hinges have broken its plastic cover so that screen is almost separated from rest of computer. Changing plastic cover and hinges is too expensive and I thought cheap solution using parts from hardware store. It works well, but I am sure it can be improved.
Bolt nuts are used to reduce length of screws so that they do not damage components inside computer, but just hold tight enough to the plastic cover
Mechanical part can be found at furniture section of hardware store.
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    I have a HP Laptop. My little brother pushed me onto it and it made a snapping noise. The Laptop was still on but the top half is wobbly and seems like it could easily be ripped off. The Laptop can be still be turned on but the screen is completely black. It still makes the noises it usually does when it's on and things that connect to it seem fine too but it's not exactly functioning the same. It can be still be turned on as I said but it's not like the screen is black but everything still works normally. It simply doesn't work now. The hinges are broke and I have to press down on them so the top half can be straight but it never stays like that. Please, if somebody could help me it would be greatly appreciated. I loved using my Laptop and I'd be very upset if I could never use it again.
    I've got an Extensa 5620z in a worse situation than yours with hinges, but my repair looks much neater than yours :P
    I've used and internal steel plate to reattach the aluminum screen frame to the hinges, and so far it's worked great.
    My instructions are at
    Your version looks great! maybe you can post it on instructables & include images how it looks like when it is closed
    After looking at your project (it looks cool) I think it would look really cool if got a bit of diamond plate, screwed the screen to it and weld some big hinges from gates to it, then after bolting them to the computer it would look relly cool.
    Hmm .. not sure if kludge or engineer.
