3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Repair rear latch on Toyota Sequoia
Step 5Get the latch assembly out of the door frame.
  • last photo ←
 Now, I carefully put on some cotton gloves and removed the door handle cable retainer clamps as shown. These clamps hold the cable in place and prevent the cable from rattling around inside the door. During reassembly, it's important to NOT just leave the cable floating around near all the gears and stuff that make the rear window go up and down.
I carefully removed the male cable connectors from the latch assembly. I used a small screw driver to loosen the connectors. There are two brass screws on the plastic outer cover surrounding the lower latch assembly. I removed the screws and very carefully jiggled the whole latch assembly out of the plastic housing. I was careful to not bend anything and DID NOT damage the white wire connector.
I am now holding the bare latch assembly.
8 comments
Apr 16, 2010. 6:32 AMsuhlee says:
great instructions!
but having trouble detaching that male connector on the left off the plastic latch cover, therefore can't get to the next step which is removing that darn plastic cover on the solenoid/latch!
Apr 17, 2010. 11:50 AMtcwinn says:
Excellent detailed, accurate (and humorous) instructions when I need it the most. Thank you for taking the time and effort to share these valuable info.
My rear latch handle just broke. I hear it snapped while trying to open it during our last ski trip on the mountain. I found the metal handle you mentioned on ebay [just search for sequoia metal liftgate handle]. Do I still need to disassemble the rear inside panel to replace the handle?
Apr 17, 2010. 3:02 PMtcwinn says:
I find the male connector comes out easily from the female. They are designed to snap in and press the latch in the middle while pulling out. What I did was pushing the middle latch with one hand while the other hand put the large flat screw driver in between the 2 connectors to lightly pry them apart. Takes 2 secs.
Apr 17, 2010. 3:13 PMtcwinn says:
The inside plastic panel is intimidating at first. Since my handle was broken, the lift gate was in a closed position so I couldn't get the putty knife or screw driver underneath the plastic to pry it open.
I had to roll down the rear windshield then use a pry bar to pry the plastic panel off from the top (after removing the window seal, of course). To my surprise, these plastic panels are attached to the car body with plastic buttons. They can be easily snap on and off. If I had known this, I could have just use the pliers and pull it off while attaching to where the pull down strap attaches.
Don't be fearful of damaging the plastic panel. Its very rugged.
Apr 18, 2010. 9:50 PMtcwinn says:
Interesting, my break light comes on intermittently [VERY OFTEN while under warranty] even while I'm driving 80 mi/hr on the freeway. I hope you didn't shell out the 1,200. I would just drive it as is. This is definitely a defect which must be covered by Toyota whether it is under warranty or not. This is BS! I would ask for money back!
I don't take my sequoia back to the dealer, because the last time I took it in for maintenance, they called me to pick up the car without refilling my transmission oil [2 qts low]. Luckily they called me to bring the car back before I drove more than 5 miles in that condition.
I listened to a 911 call before the crash of one of the Lexus brand new rental vehicle. One of the passenger on the car was the chief of car safety inspection. His wife and son and another friend were killed in the crash.
Really hate to see a good company turned horrible due to greed and arrogance. It took them a long time to build up, and just blew it in a very short time. Pride goes before the fall, like the good book says.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ronlevandoski
