iImage Information
You just broke your favorite pair of headphones and you don't feel like buying a new pair allready? Well that's just what happened to me. A few days ago I found out that someone accidentaly broke my Sennheiser hd201. Where I live (Belgium) these headphones cost €30 in store, wich is about 43.5$, so I decided not to buy a new pair. Instead I tried repairing my broken headphones.
This repair shouldn't take longer than 15 minutes. (That is if you allready have the parts)
Step 1The parts
iImage Information
I used a steel Meccano grinder/strip with 6 holes.
2 Meccano Bolts
2 Meccano Nuts
The tools I used were the standard Meccano screwdriver and wrench, a knive, a screwdriver and a drill.
after 2 yrs of using it, the leather starts to crack and fall off, and the wires are cracking too, i can even see the wires coming out of the cracked rubber. :(
besides, do you face the wires are like twisted? because, the 2 wires coming out from the headphone speakers are like twisted, i hav no idea how that happened, and i couldln't twist it back... does it happend to your headphones too?
I think the leather would last longer if you don't store it in the sun, or make sure they are dry when you store them etc. you can always buy spare parts I believe, not sure where.
Hope that helped.
Voenie
i have also tried the method of 'wrapping the jack over the split wiires' and it doesn't work even tho i wrap em both ways.. what i guess is that due to age, the rubber wires seemed to have like defecting slowly, could be that over time the rubber seems to slowly get harden, and 'twisted' itselves.
it says at the cover that this model comes with 2 years warranty, i ever asked the authorised sennheiser dealer in my country, they say only defects they would do repair for us, cause of wearing, damage by users, they shall not replace/repair ... so i guess my leather issue can't be replaced.
since one side of my headphone's wire cracked, i felt like replacing the wires where it cracked. simply by shortening the wires of the stock's wire... do you know how to remove the cover of the headphone so i could solder the wires to the speakers in the headphone cup?
hocngiap
i finally rip off the whole thing and changed the whole wire, you may find my instructable here... http://www.instructables.com/id/How-to-modify-a-2-sided-wire-headphone-to-1-sided-/
:D
if my chord is broken, i might try to fix it, i'll let you know if i have any findings as well.... :)
I think I will buy some super glue to keep them tight if they start coming off.
Super-Glue could work, if the joint didn't have to flex..
