Repair your electronics by replacing blown capacitors
 by fhidiort
Featured
Checking for blown capacitors in your malfunctioning electronics is fast and easy if know what you're looking for.  Replacing one part at a couple dollars a piece is much cheaper than replacing an entire monitor for hundreds of dollars!  Monitors, digital converters, and other video- related electronics commonly have power issues that are caused by faulty (read: low quality production) capacitors.  Common symptoms include:
- Unit won't turn on
- Unit won't return from standby
- Unit turns on and off intermittently
- Screen flickering or distorted
- Lines across the screen
If you're experiencing any of these, it's worth taking several minutes to check your circuit board capacitors.
Step 1: Tools needed
Checking the capacitor just requires your eyeballs but replacing them requires a few tools:
- Screwdriver, hex wrench, or whatever's needed to open the case
- Soldering iron
- Replacement capacitors (you will find the values for this in the following steps)
Also optional but helpful is soldering wick, which is available for fairly cheap at Radio Shack.
In this example I'm repairing a digital TV converter box that will power on, but does not activate from standby.
Step 2: Open the case
Most important: power off and unplug your unit!
Using your screwdriver or other tools, open up the electronics case so that you have easy access to the circuit board.  If you're having trouble, look up the manual online to find out where the various screws and tabs are to open the case.
Bring it up the light so you can see the electrolytic capacitors easily.
Step 3: What a blown capacitor looks like
A busted capacitor can be obviously broken (leaking brownish fluid, corroded, or with the leads severed), but sometimes it's subtle. The top of a blown capacitor will be slightly bent outwards in a convex shape, rather than flat or slightly indented inwards like a working capacitor.  See the photos above for examples.
Think of it like a vacuum-sealed glass bottle.  When the seal is intact, the bottle cap is flat, and when you break the seal, the bottle cap pops up.  That subtle "popping-up" is exactly what you're looking for.
Step 4: Remove the old capacitor
Make a note of the polarity of the old capacitor, and mark the exact values you'll need for the replacement: capacitance and voltage/temperature ratings (these may be written on the part itself, or you can look up the part number).
Press the tip of a heated soldering iron directly onto the solder joint on the back of the circuit board that is holding the old capacitor down.  Hold on to the capacitor itself with your other hand.  As the joint melts, you can feel the tip of the iron fall into the hole of the circuit board.  As soon as it does, pull that side's wire lead out of the board.  Then repeat with the other side.
This can take a bit of trial and error.  The goal is to dig the very tip of the iron into the joint so that the solder in the hole heats and melts.  If there's too much solder for your iron to reach the hole itself, you may want to use a soldering wick to get rid of some of the excess.
Also, be aware that some manufacturers use solder that cannot be melted by a typical hobbyist soldering iron.
Step 5: Insert the new capacitor
Trim the leads of the new capacitor so that they are both even, and will sit at about the same height as the old capacitor.
Position the new capacitor leads at the holes where the old capacitor was, with the correct polarity.  Just like before, press the tip of the soldering iron directly onto the joint in the back of the circuit board.   As soon as the tip falls into the hole, press the wire lead through the hole, then remove the iron.  The old solder joint will solidify around the new part and hold it secure.  Repeat with the other side.  Add new solder to the joint if necessary.
Step 6: Working now!
Replace the circuit board in its case and test the power and output.  The electronics should work now!
raptor402 says: Mar 18, 2013. 3:54 AM
Hello, sir/ma'am
Your instructable is wonderful. I have a question: I have an XBox 360 slim with a 100-127v input power supply. In my country, the wall outlets are all 220v, so I was using a step-down transformer with the console. Unfortunately, I tried out a smaller converter without reading that it was not transformer based. To sum it up, there was a bang and some smoke.
I opened up the adapter and found that one big capacitor had burst open (that was my first guess as I had seen a capacitor burst with my own eyes, and that was my own doing) and the electrolyte was spread around. I cleaned up the electrolyte and tried the adapter. The console would work for a minute and then shut down, implying that the rest of the adapter is function.
My question is: will replacing the capacitor fix the adapter and make it usable again?
rbennett8 says: Sep 3, 2012. 6:14 PM
i can vouch for this i had o recently recap my 26" lcd tv due to it turning on and off intermittently
i recommended this site they will help you out a lot with the process
http://www.badcaps.net/
http://www.badcaps.net/forum/
also the desoldering wick from radio shack from my experience is junk
this one is good i have not had a problem with it yet
http://www.drillspot.com/products/1429031/Tech_Spray_1811-5F_Desoldering_Wick?s=1
crowman73 says: May 15, 2012. 12:24 AM
I'll definitely use this tip in future, thanks.
nickmccullough says: May 13, 2012. 9:23 AM
thank you sir, very helpful.
i had a DVD player stop working, turns out it blew the switching power supply IC, and a fuse as well. I replaced them and the unit still didnt power on.
i had overlooked a couple of blown caps, so thanks for reminding me to take a second look! all is functioning well
Dr.Bill says: May 13, 2012. 2:49 AM
I always suspected the tops of the caps were scored for a reason.
Horsehockey says: May 12, 2012. 7:23 AM
You say to note the polarity of the capicator. Trying to determine the polarity of capicators, especially on well pump motors or other outside erquipment, has always baffled me. Maybe the little blue capicators have the polarity on them.
I have asked many highly intelligent electronics technitians how to determine if a capacitor was bad. Their reply was that if they thought it could be bad they replaced it. You are the first person I have seen that has come up with a simple way to dewtermine a bad capicator. Thanks for sharing.
fhidiort (author) in reply to HorsehockeyMay 12, 2012. 10:23 PM
Usually electrolytic capacitors have a stripe with minus signs down the side that indicate the negative lead. You can see in the Step 5 picture the blue capacitor has a black stripe with blue minus signs- that's the negative end. Also on some circuit boards (including the one used in this example) the polarity is marked on the board itself with a little plus and minus sign.
dimmaz88 says: May 6, 2012. 11:21 AM
Awesome instructable. The trick for identifying the broken capacitors is great, I've always wondered how to do so.
Thanks for sharing.
samalert in reply to dimmaz88May 8, 2012. 7:27 PM
coming from non electronics i was really glad you explained the thing with simplicity. Loved it !
fhidiort (author) in reply to dimmaz88May 7, 2012. 7:03 AM
Glad it helped!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
