- Unit won't turn on
- Unit won't return from standby
- Unit turns on and off intermittently
- Screen flickering or distorted
- Lines across the screen
If you're experiencing any of these, it's worth taking several minutes to check your circuit board capacitors.
Remove these ads by
Signing UpStep 1: Tools needed
- Screwdriver, hex wrench, or whatever's needed to open the case
- Soldering iron
- Replacement capacitors (you will find the values for this in the following steps)
Also optional but helpful is soldering wick, which is available for fairly cheap at Radio Shack.
In this example I'm repairing a digital TV converter box that will power on, but does not activate from standby.
Visit Our Store »
Go Pro Today »
Your instructable is wonderful. I have a question: I have an XBox 360 slim with a 100-127v input power supply. In my country, the wall outlets are all 220v, so I was using a step-down transformer with the console. Unfortunately, I tried out a smaller converter without reading that it was not transformer based. To sum it up, there was a bang and some smoke.
I opened up the adapter and found that one big capacitor had burst open (that was my first guess as I had seen a capacitor burst with my own eyes, and that was my own doing) and the electrolyte was spread around. I cleaned up the electrolyte and tried the adapter. The console would work for a minute and then shut down, implying that the rest of the adapter is function.
My question is: will replacing the capacitor fix the adapter and make it usable again?
i recommended this site they will help you out a lot with the process
http://www.badcaps.net/
http://www.badcaps.net/forum/
also the desoldering wick from radio shack from my experience is junk
this one is good i have not had a problem with it yet
http://www.drillspot.com/products/1429031/Tech_Spray_1811-5F_Desoldering_Wick?s=1
i had a DVD player stop working, turns out it blew the switching power supply IC, and a fuse as well. I replaced them and the unit still didnt power on.
i had overlooked a couple of blown caps, so thanks for reminding me to take a second look! all is functioning well
I have asked many highly intelligent electronics technitians how to determine if a capacitor was bad. Their reply was that if they thought it could be bad they replaced it. You are the first person I have seen that has come up with a simple way to dewtermine a bad capicator. Thanks for sharing.
Thanks for sharing.
