Remove these ads by
Signing UpStep 1Slide back the sheath
Assuming yours is intact, I think a good swift twist/tug with a pair of pliers should snap it loose.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
from a quality power supply cord
manufacturer
What I did notice was something that may have contributed to why these are flimsy -- the braid wasn't tinned in the original hookup, not even twisted, and the nylon was still flopping about in there. Can't possibly have been a good connection.
Any suggestions on how to connect this braided wire with the end connected to the plug?
Thank you for saving me $75!!
I decided to take on this project after fixing two dead (logic board issue) G3 ibooks with the amazing 26cent method http://www.fak3r.com/2007/05/29/howto-fix-a-g3-ibook-with-a-bad-logic-board-for-26-cents/ (just open the lower case and tape a quarter and penny to the metal housing outside where the VRAM chip is located !)
Next here is the fix for an adapter that had frayed wire to the power brick: http://theappleblog.com/2005/08/13/powerbook-65w-ac-adaper-repair/
But getting back to your fix --
I would have never dreamed the adaptor plug end could have been repaired, but your post gave me the guts to go for it. (That and my not wanting to shell out $80)
The adapter plug is a tough nut to crack -- literally. It's not like you can even
dream of popping it apart.
For those not fortunate (?) enough to have a pre-cracked plug case like you did-- if you put the connector in a vice, it can be cut off fairly easily with a box cutter. I cut it into two halves by splitting it up each side, which made it really easy to put back on after the repair.
My connector guts were in fine shape and the solder to the plug was fine. The problem had been a worn cord where the wire comes out of the plug -- frayed to the point of sparking, so I really just needed to take the outer plug off; cut the bad length of wife off and re-solder. Be sure to put the shrink tubing on BEFORE soldering the wire. LOL. We used a piece of black electric tape around the plug casing to further enhance the binding effects of the glue gun. I like to think it gives the thing a decorative sushi look. Thank you for the excellent pictures and instructions!
